80s TW CDI Reverse Engineering
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
    Junior Member 82indypc's Avatar
    Sep 2011
    Rochester NY
    20
    Hi All:
    Myself and another engineer are working on reverse engineering CDI units for our BW200 and BW350
    bikes. These have become almost impossible to find, people buy bikes just for the CDI, and when
    available they are expensive $300-$500.
    We see the TW200 1980s models have almost the same motor and CDI unit. I own a 2003 TW and
    a buddy has an 87. As I understand it they change the CDI in 88 and then it remained the same
    for a bunch of years.
    What I am looking for is any dead TW200 CDIs that anyone may have and are willing to donate
    to the project, I can pay for shipping to me as needed.
    We are depotting a dead BW200, BW350 CDIs that we are getting from the yahoo Big Wheel group
    I am in, similar to this group but on yahoo, check us out.
    http://autos.groups.yahoo.com/group/YAMAHABIGWHEELS/
    The plan is to redesign the CDI units to use more modern electronics, programmable
    spark advance curves and add protection from failure. The old blown units give
    us insight into what to protect in the new design and to see whats common among these
    very similar bikes.
    We have used our x-ray machine to look inside two of my working CDIs, here is an
    link to some images, its pretty cool that we can look right through the metal case
    on the CDI unit. My next task is to depot the dead ones that are on their way to
    me and compare components.
    https://picasaweb.google.com/82indypc/CDIProject
    The objective is to make units available that are hard to get and expensive, so
    we call all have a couple spares to test out when our bikes start acting up, and
    replace them when they die.
    It kills me to see bikes parted out on ebay just because the CDI died.
    I appreciate any help anyone can offer. I will become more active in this
    group once I get my TW out of storage and on the road and finish my BW200 restoration
    project.
    Cheers
    Tim
    Cheers
    tjs
    Jul 2011
    1,123
    ummmmmmmmmmmmmm. WOW!
    Check out a couple of my old threads on here, I guess
    ITCB
    Desert, SoCal
    7,369
    Remains to be seen if he's as operose as Operose..... iz.
    Jul 2011
    1,123
    For his sake, let's hope not. My bike can't move under its own power (still? again? i don't even know anymore)
    plus it is off of the ttr cdi and onto a "proper" setup from a 98 tw200 because i was lazy and let it all get chewed up inside the motor
    ITCB
    Sep 2011
    Rochester NY
    20
    Quote Originally Posted by operose View Post
    OK I am new to this site and dont know my way around yet. I take it there have been
    discussion by your before on the TW CDI topic. If there is some question as to
    my ID or intent you can check out my history on the BW site, there I am pungoclassic.
    Cheers
    tjs
    Jun 2011
    Dothan, AL
    1,715
    Quote Originally Posted by 82indypc View Post
    .....Myself and another engineer are working on reverse engineering CDI units for our BW200 and BW350
    bikes....
    Isn't there an App for that?
    Good Luck with your project. I know a lot of people need help with CDI issues. I'm sure you have a good market for a replacement CDI.
    2005 TW200 (SOLD)
    2013 DR650
    Jul 2011
    1,123
    No need to question your intent, we are all friends here. Besides, "I pity da fool" that thinks having busted CDI units shipped to him is a good or profitable scam
    Just some guy on the internet that had cdi problems that one time.
    You should really dig up the thread(s)
    ITCB
    Senior Member Dave Nafziger's Avatar
    Aug 2010
    264
    Sure, BW. I have a partially de-potted CDI from a TW200, Jan '89, unless it is not original. Send an appropriate SASE envelope to:
    DN
    When you succeed, add a "Check Engine Light" dedicated to ignition.
    My best, GB
    Senior Member tw200sgp's Avatar
    Mar 2012
    Singapore
    258
    There's not a lot of active components in that! I was originally an EEE many years ago. I honestly don't think there's think that much difference between the AC CDI systems of older bikes - they have a charging coil and a firing coil. If you match the wires up correctly for the coils I suspect they will work on your BW200.
    Mar 2012
    Singapore
    258
    Take a look at this. The best schematic (simplest) I've seen, I reckon that the Bosh coil with built in CDI would be an easy fix for your problems.
    Once again - there's only two coils - the charging voltages are not overly critical and there are only 4 wires to sort out.
    I'm an old schooler who rewired a PE175 CDI system back in the 80's in a country we couldn't get parts so I'm not talking out my ass.
    Do you have a fluke scope meter?
bosch cdi unit
bw 200 cdi
bw200 cdi
bw200e engine
bw80 cdi
capacitor discharge ignition circuit diagram
cdi diagram
cdi schematic
wiring diagram cdi yamaha y110
yamaha bw200 cdi
yamaha nig wheell cdi
yamaha y110 wiring diagram
