Best year
Results 1 to 6 of 6
Thread: Best year
    Junior Member JWillett's Avatar
    Mar 2012
    5
    What was the best year for the Tw or which year had the most mechanical changes?
    Desert, SoCal
    7,369
    There is no "best" year.
    The 87's are prone to CDI failure and for that reason ONLY they could be said to be the "worst" year. Other than the electrical system they're mechanically identical to an '88-'00 TW.
    In '01 they got a disc front end, higher stator output and a CV carb. Quality went to heck (from an already low standard), and they lost their kickstarter. Other than that they're also essentially mechanically identical to an '87.
    If you're mechanically inclined and do your own work, go old.
    Not so mechanical or just in love with that "new bike smell" go new, and maintain it meticulously.
    No clear winner among them.
    Mar 2012
    5
    Thanks for the quick post, thats the kind of info I'm looking for. Had 2 TW's in the past, regret selling both. Looking for a 2006/2007 now but has to be a Calif. bike. thanks again
    In '01 they got a disc front end, higher stator output and a CV carb. Quality went to heck (from an already low standard), and they lost their kickstarter. Other than that they're essentially mechanically identical to an '87.
    [/quote]
    Mar 2011
    Gobles, michigan
    1,824
    Some of the 06 bikes develop base gasket oil leaks.... OK. Most of them do.. If you have it fixed try and order the 2010 gasket or newer.. Better design... We have two 06 models,,, We are crazy about them. OMM.
    Desert, SoCal
    7,369
    Another misconception regarding Cali bikes You aren't "stuck" or "settling" when you buy a Cali TW:
    The ONLY difference in a CALI TW (keyword "TW") is the tank venting. It has ZERO moving parts, causes no service problems and has NO effect on performance. End of song.
    Cali jetting is typically one step RICHER than the other 49. So don't go dinking with jetting til you know you need it.
    The internet is loaded with "De-Californication" threads. Pure crap. Bikes like the TW are still in the lawnmower class in terms of emission regulations. If anything Cali TW's run BETTER than 49-state bikes right out of the box.
    In fact I can name at least 3 reasons why the Cali TW system is actually superior, but the jerkweeds in Sac might overhear and notice that they haven't ruined our joy. They'd then move to correct that.
    Ephrata, WA
    1,125
    I think 1990 is the best year!
    1990 TW200
  1. 1987 Model Year - First Year for TW200's - Good, Bad, Ugly?
    By TW-Brian in forum General Discussion
    Last Post: 01-07-2019, 01:52 PM
  2. what year?
    By keithert in forum General Discussion
    Last Post: 01-10-2013, 07:34 PM
  3. After a year
    By Ssokzon in forum General Discussion
    Last Post: 10-15-2012, 08:48 PM
  4. The last year
    By phelonius in forum General Discussion
    Last Post: 12-23-2011, 08:53 AM
  5. What year do you think this TW is?
    By Rohnsman in forum General Discussion
    Last Post: 06-09-2011, 04:38 PM
best year to buy
