Squirrley tw!
Results 1 to 10 of 13
Like Tree28Likes
Thread: Squirrley tw!
    Junior Member Hag1's Avatar
    May 2017
    Squirrley tw!
    I bought a new 2013 tw 200 and its a great little bike although it gets (very) squirrly in sand.
    To me it feels like the bike is front heavy and always in a nose dive.
    I am about 220lbs and feel like i have to slide as far back on the seat as i can to keep weight off the front end!
    Anybody else have these issues??
    Thanks hag1
    Ken likes this.
    Senior Member GCFishguy's Avatar
    Oct 2016
    Moncton, New Brunswick, Canada ehh?
    343
    Welcome. Something I've learned since I got here is whatever question I'm about to ask, has already been asked and discussed several times.
    The latest sand thread was here: https://tw200forum.com/forum/trails-o...ugar-sand.html
    The end result is, sand sucks.
    Enjoy!
    Ken likes this.
    Pleasanton, CA
    5,783
    I would suggest that you check the oil level in your forks. TW's typically come from the factory with insufficient oil in the fork legs. The proper level for someone your size should be about 130mm from the top of the fork leg.
    If your bike still has the stock front tire, I strongly suggest that you replace it. The current, most popular replacement tire seems to be the Shinko 241 4.0 x 18.
    As said before, sand sucks.
    Ken likes this.
    May 2017
    Thanks! Your answer and link led to some good advice.
    Ken likes this.
    Jun 2014
    Bel Air Maryland
    4,170
    The first time I rode in sand I broke my ankle within 15 minutes. Then the seasoned guys taught me how to ride in sand. Sit back on the seat and "Give it Hell"
    https://tw200forum.com/forum/general-...roken-leg.html
    centralwarider and Ken like this.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Sep 2014
    Mamaroneck, NY
    2,196
    Sit back and twist the throttle as far as it goes and merely suggest where you want to go. Do not grip the bars too tightly.
    And get rid of the factory front tire.
    The Deathwing is aptly named.
    Sent from my SM-G955U using Tapatalk
    Mar 2012
    Boonville, No.-Calif.
    1,366
    Quote Originally Posted by Smitty Blackstone View Post
    What He said! m.
    Ken and TopPredator like this.
    Frosty Hollow
    13,174
    Until I opened the thread this is what I was thinking. I'm just being a goofball today but you'll get plenty of good advice here for sure with the shock settings and better tires.
    Fred, Tweaker, LuvNot and 4 others like this.
    Senior Member ChopperCharles's Avatar
    134
    Loose sand at the beach was a paddle-walk event. Horrible. The wet stuff near the water was better, but the TW had insufficient power to go more than 30mph, flat out, in that kind of sand. whole bike felt really, really heavy. It was fun as hell though! Tried the sit back and gun it through the soft stuff, and that might work if the TW could ever get a decent speed going, but the deep powder sand at the outer banks is just too much I think.
    Charles.
    Modified Motorcycles by ChopperCharles:
    Dec 2015
    San Diego
    1,865
    This is why guys are putting atv tires on the back and regearing.
    Ken likes this.
