Am I being too uptight?
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Like Tree74Likes
Thread: Am I being too uptight?
    Member Roseburg's Avatar
    May 2017
    OR
    45
    So far, as i get close to home from a ride, I turn the petcock off so i can run the carb bowl empty before I park it for the day.
    Yesterday I forgot to do this until I pulled up in front of my garage. So I was just letting it sit there idling..when I thought shoot! I don't want to overheat it. (It was in the upper 80s) So I got the leafblower out and put some airflow to the motor until it ran the carb out of fuel.
    Ken likes this.
    Senior Member mountain yawp's Avatar
    Jul 2016
    Right side of Oregon
    552
    You better use two leaf blowers next time, one on each side so it doesn't cool unevenly. I heard that's worse than an oil filter with only one hole. ?
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    Yeah, not needed imo. Park/shut off valve/done.
    GaryL, littletommy and Ken like this.
    2005 TW200
    2007 Sportster 1200
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,130
    Actually the term is ANAL! Turning off the fuel is a good practice but there is little need to run the float bowl dry after every ride. Even less if you use the bike fairly regular.
    There are two schools of thought on this subject, mostly concerning long term storage. Run the bowl and tank completely dry or keep both completely full. The debate rages on and it is a matter of your own personal belief. I go with the crowd that keeps the tank and bowl wet and filled right to the top but I never, ever use any fuel that contains ethanol in any of my small engines. I just don't know what benefit there could possibly be from running it out of fuel after every ride.
    1987 Yamaha BW350 Big Wheel
    Jun 2014
    Bel Air Maryland
    4,170
    The only motor I run the bowl dry on is my 1988 Johnson 9.9 outboard motor. Still runs like new.
    GaryL, littletommy, Ken and 1 others like this.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Nov 2010
    Frostbite Falls Ill
    2,719
    Yes----------
    Purple, Ken and oatmealx like this.
    Phelonius
    Jun 2013
    Forestburgh, NY
    8,130
    Quote Originally Posted by TopPredator View Post
    I never had a Johnson/Evinrude as new as 1988! Have had many, many outboards in this class and they are all like Timex! All have been 2 cycle motors with mix your own fuel and oil and as long as you keep that crappy ethanol out you should be good to go weather you drain the bowl or not. All these small engines that get very little use and spend a lot of time between usages are subject to fuel separation so using just real gas, good 2 cycle oil mixtures and dosing it with Sea Foam is a standard necessity. Chain saws, weed eaters, Ice Augers and all sorts of small engine equipment will benefit from good gas and I think keeping the float bowls wet is just as good if not better than dry. Just my opinion of course and we all no about opinions.
    Hailey, ID
    3,405
    The only time I would ever run the carb dry is when I'm storing it for the winter. I put in an ounce of Stabil, run it up and down the street for three minutes to get the Stabil into the carb, turn off the petcock run it up and down the street for two minutes, then get real close to the barn and ride it in circles it until it stops.
    Lately, though, since I can get Non Ethanol fuel easily, I just put in an ounce of Stabil, close the petcock, and call it good. It starts right up in the spring.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    May 2017
    OR
    45
    I hear you guys loud and clear on the Ethanol in fuel thing. I remember when the state MANDATED ethanol in fuel several pilot associations raised so many concerns that they got an immediate exemption. Then the boat owners, which I think was crucial because non-E fuel became available at gas stations. BUT, they were not allowed to pujmp directly into road vehicles..until I believe it was owners of older vintage type cars discovered (the hard way) that Ethanol is not good for O rings and other rubber things.
    I KNOW there is less energy gallon for gallon with E fuel as well. Performance and mileage suffer with it. The state likes that because less fuel economy means more fuel consumed which means more gas tax collected.
    Ken likes this.
    May 2017
    OR
    45
    Doesn't this say something about the practice of running the bowl dry?
    TopPredator and Ken like this.
