Headlight shroud problems
Results 1 to 7 of 7
Like Tree18Likes
  • 1 Post By Parkerbhobbs
  • 4 Post By old w/??
  • 9 Post By PlacerLode
  • 1 Post By Ken
  • 1 Post By socalnative
Thread: Headlight shroud problems
    Junior Member Parkerbhobbs's Avatar
    Jun 2017
    9
    Hi I am a new user and I got a 2003 tw200 with 2000 miles on it. It is stock other than the racks and a very clean bike. I have one problem though, the headlight shroud comes loose. The screw on the bottom is fine but where it hooks to the rubber peices on either side, itwont stay on. Any help would be greatly appreciated. Thanks,
    Parker
    Ken likes this.
    Apr 2014
    993
    The screw may be tight; but you could loosen it and see if the shroud will slide upwards and re-tighten it.
    Jun 2017
    9
    Thank you
    littletommy likes this.
    Apr 2012
    Out West
    3,066
    the steel headlamp bracket ( headlight stay) can be easily tweaked especially the two upper ears where the grommets are so you can tweak it around a bit and bring it back to specs
    "It's Like Warm Apple Pie"
    Jun 2017
    9
    Thanks I will try it
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,968
    Welcome to the forum.
    Nov 2016
    So. California, inland empire
    309
    The above responses are correct. Just take out the screw at the bottom and the shroud "tabs" should be right under the rubber grommets. If not carefully bend the mount back. They are pretty sturdy but can get knocked out of alignment during a fall. The shroud will not fall off but it won't stay connected with the vibration during riding. Mine got bent from another motorcycle falling partially on it but I didn't notice the issue until I saw that it wasn't in the rubber mounts.
  1. 1994 Headlight shroud needed
    By Smitty Blackstone in forum TW200 Classifieds
    Last Post: 10-15-2014, 08:05 PM
  2. Wanted: 1990 front fender, shroud
    By TWrider in forum TW200 Classifieds
    Last Post: 04-26-2014, 06:28 AM
  3. wanted fender and head light shroud
    By belterskelter in forum TW200 Classifieds
    Last Post: 06-18-2013, 04:16 PM
  4. distance from bottom of forks to top of headlight shroud
    By mrkipper in forum General Discussion
    Last Post: 01-26-2012, 04:41 PM
  5. Where to get Yamaha logo decal for headlight shroud?
    By darnold87 in forum Performance and Customization
    Last Post: 11-06-2010, 10:53 AM
