Another Newb - with questions
Results 1 to 10 of 13
    Junior Member kgriff's Avatar
    Apr 2012
    26
    I just bought a '96 today. Not in great shape, not terrible. Did a lot of lurking here prior to buying and looking at reviews, specs, etc. My other bike is an '05 Goldwing, and I haven't ridden a bike like this in something like 20 years, so I'm looking forward to gobs of fun with it.
    So, as the title suggests, I've got a couple of questions, and things to have confirmed, or disputed.
    I've seen elsewhere on this forum that the stock sprockets are 14/50. Is this the case? This bike has 44 teeth on the rear, and I don't yet know what's on the front. Since I have a Goldwing for highway riding, this will mostly be off road. Is 14/50 the best for light to moderate off-roading? (Since I haven't ridden any dirt bikes in a long time, I'm sticking with "light to moderate" for now.)
    Since some dirt biking years ago, I had a long gap of no motorcycles until about 6 years ago. Since then, I have only owned shaft-driven bikes, so I'm pretty ignorant of chain technology. I've seen a lot on this forum about O-Ring chains. Can anyone tell me what is the advantage of O-Ring chains? Do O-Ring chains require special sprockets, or are normal sprockets okay?
    Now the really strange question. Can someone tell me how the front brake lever is supposed to "feel"? The brake is well within the wear limits, but the lever doesn't feel right to me. I have to pull the lever nearly to the grip before I get good braking. It almost seems like I don't have much in the way of gradual braking. It's either no brake, or full brake. Is this normal, or is it just that I'm so used to hydraulic brakes that this seems strange to me?
    Mar 2012
    Boonville, No.-Calif.
    1,357
    The stock gearing is great for most everything trail related. Keep the chain well lubed & adjusted. When you change your chain & sprockets, you will know if you want to change your gear ratio or not, but do go with the o-ring chain, they are far better.
    Your front brake on the other hand, now that’s not right. Is it a drum brake? Better have a good look at that.
    Welcome to the TW club! m.
    Pleasanton, CA
    5,740
    Welcome!
    You're right, stock sprockets on domestic TW's are 14/50. With a 44 sprocket on the rear, this bike was set up for street riding and will be geared too high for serious off-roading. A 50 rear sprocket would be much better suited to your planned light to moderate off-roading.
    The O-rings serve to keep the chain lubricant where it belongs and to keep water and dirt out. O-ring chains offer less wear, reduced maintenance and longer life. O-ring chains use the same sprockets as non-o-ring chains.
    It sounds like your front brake cable has stretched and needs adjustment to take out some of the slack. There are adjustments for this both at the handlebar and at the brake hub. Turn the adjusters out a few turns and see if that takes some of the free play out of the brake lever.
    Apr 2012
    26
    Welcome!
    Apr 2012
    26
    Thanks for the replies.
    I've already adjusted the cable to the extent that I feel comfortable with. If I go any farther I'm afraid I'm going to have dragging brakes. My next step is to take the brakes apart and see what's going on. At this moment, I don't have a service manual, and I'm a bit leery of tearing into these without having some sort of guide.
    The other part I failed to mention about the brakes is that the lever does not return all the way when it's released. It seems to me like the shoes aren't moving quite like they're supposed to. My guess is that the brakes have never been apart and 16 years worth of neglect has them somewhat stiff.
    Pleasanton, CA
    5,740
    Here's a link to the manual:
    http://www.mediafire.com/?34muedntyxz
    It also sounds like your brake cable could use some cleaning/lubrication. That should help the spring return the lever when the brake is released.
    Tighten your cable to the point of your brake pads dragging and then back just enough to stop the dragging. Drum brakes are marginal at best and are never going to be as good as more modern hydraulic brakes.
    Apr 2012
    26
    Thanks for the tip and the link. I'll give it another go tomorrow, time permitting.
    Ephrata, WA
    1,125
    Quote Originally Posted by kgriff View Post
    The front brake is a pretty simple design. If your lever isn't returning it could be a couple things. Your pivot bolt that holds the lever on needs some lube, your brake cable is stretched and needs to be replaced, or the two little springs that hold the shoes on are rusted.
    I'd lube the pivot bolt and cable first. If that doesn't help, take off the front wheel and check it out.
    I went out and took some pictures for you with a spare brake assembly.
    Here is what the brake would look like with no brake applied. Note: there are some parts missing from my spare. There is a set of gears in there that spin the speedometer cable, but they are held on by a snap ring and won't fall out.
    And here is what it would look like if the brakes were applied. Notice the bottom rectangular thing moves and separates the shoes.
    Another angle
    Go ahead, take it apart. Nothing is going to fall out. Download the manual first though...it does help.
    1990 TW200
    Ephrata, WA
    1,125
    I was a non-believer as far as o-rings chains go. I'll admit it, I thought they were just some expensive chain that wasn't needed. Are they far superior? Eh, maybe a little bit. I clean my chain when its dirty so having a sealed chain was just a bonus, but what I noticed was the stretch. My open chain would need adjusting every 100-150 miles (about every other off-road ride). I got tired of pulling the rear cotter pin, undoing the axle and adjusting the chain. I got a new set of sprockets and an o-ring chain and what a surprise. It needed an adjustment after my first ride and hasn't needed anything other than cleaning since. I've put on about 300 hard off-road and some street miles on it and it hasn't stretched at all.
    If you are going to get new sprockets, buy the o-ring chain, you'll be happy you did.
    1990 TW200
    Apr 2012
    26
    Rainman, thanks for the pictures. I've downloaded the manual and the pictures in it leave a lot to be desired.
    I'm no stranger to drum brakes, as I only got my first disk braked vehicle about 8 years ago and I do all of my own mechanic work. However, I've never had them apart on a motorcycle before. These are really simple, from the pictures you've got posted. I had assumed it was probably a return spring, either weak or with too much crud built up for it to work properly. (Probably build up, since I've never had to replace a return spring on a car.)
    I've already applied a bit of deductive reasoning and lubed the lever and pivot, and the cable. (Again, not a complete stranger to cable operated brakes. i.e. parking brakes on cars) Also, I've adjusted the cable and it doesn't seem to be stretched excessively, as I still have adjustment left.
    I'll just have to wait and see what tomorrow brings and maybe I'll have time to tear into it then.
    Again, thanks for the pictures.
  1. Newb Here, first timer
    By JTH90 in forum General Discussion
    Last Post: 02-27-2012, 08:33 AM
  2. New exhaust Newb question
    By chevyy1212 in forum Technical Help
    Last Post: 12-25-2011, 01:14 PM
  3. Newb x 2 in Pa
    By CalicoJack in forum General Discussion
    Last Post: 03-23-2011, 03:02 PM
  4. Newb with a used TW
    By ceoutman in forum General Discussion
    Last Post: 02-10-2011, 01:38 PM
  5. newb howdy
    By sMoOsHy in forum General Discussion
    Last Post: 08-19-2010, 01:15 AM
cable lubricating
tw200 how to tell front brakes are worn
tw200 rear brake wear indicator
