How much Mileage on your TW
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Like Tree93Likes
Thread: How much Mileage on your TW
    Senior Member Tw200quebec's Avatar
    Oct 2016
    164
    I was just wondering, what sprocket set up is recommended Also thinking of swapping my rear sprocket (50 teeth) for a 47 or maybe a 45. Would need people's feed back on those whom have done this change.
    admiral, Cornelis and Ken like this.
    Nov 2010
    Frostbite Falls Ill
    2,719
    A 37 tooth rear sprocket would be ridiculous.
    Ken likes this.
    Phelonius
    Frosty Hollow
    13,095
    Quote Originally Posted by Tw200quebec View Post
    I was just wondering, I have a TW 200 2013 and do quite a lot of millage, mostly dirt roads and paved and cruze at an average of about 70 KMh. How much millage do some of you TW owners have without touching the motor. I heard about some TW's having 30K km and more with original motor and tranny!! Also thinking of swapping my rear sprocket (50 teeth) for a 37 or maybe a 35. Would need people's feed back on those whom have done this change.
    Welcome Tw200quebed, enjoy your TW.
    You may want to read this thread regarding which sprockets to use or not. https://tw200forum.com/forum/performa...earing-13.html
    Ken likes this.
    Stanwood,Wa
    1,898
    Not enough HPs for that small of a sprocket. Smallest I have heard of is 42. That's what came on mine and I changed it pretty fast. I now run a 52. Oh and I have 12,350 approx. on my TW now.
    Ken likes this.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    18,845
    Someone here has put over 80,000 kilometers on their TW without need for engine nor transmission repair. Of course owner would never have achieved that with a 35 tooth rear sprocket, the “lugging” would be murder on the lower end and the clutch would not last long with all the slipping required to get the TW moving.
    ken.cooley.311 and Ken like this.
    6,985
    52,500 kilometers and going strong. Different piston and cylinder but everything else original. I changed the piston and cylinder for larger ones with higher compression in search of more power, speed, and economy.
    i vote for 45 teeth.
    Ken and Peterb like this.
    Junior Member ken.cooley.311's Avatar
    Jun 2017
    3
    Why change it anyway?
    Engineering built a good machine, ride it as is.
    What are you attempting to accomplish?
    Sent from my SM-G920V using Tapatalk
    Ken, 2scoops and Cascade Rider like this.
    Senior Member rmartin's Avatar
    Quartzsite, AZ/ Hoopeston, IL
    392
    Illinois TW 12,030 carb needs work, float leaks if gas is not shut off, jugs leaks
    Arizona TW16,013 head gasket leaks,
    might add add I have Suzuki gz250 I ride also that has over 10,000 miles.
    all three bought used with 250 to 2500 miles on them. So between the three I have put on about 33,000 miles
    Bobo413 and Ken like this.
    Senior Member Hoot Gibson's Avatar
    Dec 2013
    Grand Lake Ohio
    4,417
    2104-purchased new on 03/20/14....6513 miles and nary a touching of engine or anything, except new front tire, new chain, oil changes, and swapping out rear rack a couple of times...well and twice clutch levers changed {Hoot with cases of "Dropitis"
    Still original spark plug, oil filter{the medal stock one is great and cleaning is EZ}....
    Hoot's Ride Slide Show Music Videos
    TW Adventure Rides Completed
    March 2015 Moab: With 30 TW Forum Friends..
    Summer 2015 Great Lakes, Wisconsin, UP of Michigan, With Borneo and Montezuma
    November 2015: SE Ohio/West Virginia w/ Borneo and Montezuma
    March 2016: Big Bend NP in South Texas w/ Montezuma, Borneo, Ebbanflood and FW Gary
    August 2016: Montezuma and Hoot's Covered Bridge Ride in Southern Indiana
    May 2013
    Groton, NY
    2,663
    11,550 miles on my '13. Just the normal maintenance stuff and new o-rings on the valve and timing chain covers. Tried a 47 and 48 tooth rear sprocket but went back to the 50. If I'm going to do a lot of pavement at 60 mph, I'll take the KLR or the 1600.
    Bobo413, littletommy, Ken and 2 others like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
  1. Tire mileage?
    By Woodi23 in forum General Discussion
    Last Post: 05-08-2013, 07:46 PM
  2. mileage
    By plumbstraight in forum Technical Help
    Last Post: 05-06-2013, 08:20 PM
  3. Mileage
    By Pinittowinit in forum General Discussion
    Last Post: 09-29-2010, 08:31 AM
  4. Mileage
    By WINGNUT200 in forum Performance and Customization
    Last Post: 08-25-2010, 09:37 PM
