A few questions.
Results 1 to 10 of 10
    Member Revolverman's Avatar
    May 2012
    TENNESSEE
    70
    Hello, I have a few questions I just could not wait until tuesday (when I pick it up) to ask.
    What is the seat cover I am seeing on some bikes and is it nice ? For comfort ? To protect the original ?
    I noticed when I test rode it yesterday, the front turn signals stay on, normal ?
    Mine is an 03, will my head light stay on all the time or can I turn it off when in the woods ?
    Will I need a crank installed ?
    I read about a kit, where and how ?
    Is it worth it ?
    Can you roll start these if needed ?
    I'm seeing a lot about the larger pegs, is there any that fit 100% without grinding or mods ? If so, where ?
    Do I need to use stabil in tank sometimes or carb cleaner like sea foam ?
    Are the turn signals really unbreakable or just flexible to a point ?
    Thanks for any help.......
    Revolverman.
    The older I get, the more I realize it's easier to be kind in most situations.
    Ephrata, WA
    1,125
    The seat cover you see is from Cabelas
    It used to be a Stearn's and it came from Walmart but they don't carry them anymore. Its pretty much the same cover though. It helps keep your butt happy on the longer rides. Needed? Its nice to have.
    Front turn signals (running lights) do stay on when the key is on. Its normal.
    Your headlight will stay on with the key. Most states require on-road motorcycles to have a constant on headlight that you cannot turn off. There is a thread on the forum that explains how to grind off a little of the inside of the switch so you can switch from low to high then to off, BUT this is only for the older bikes. Can't remember if there is a way to do it for the newer bikes (like the one you have).
    A kick starter is a great idea. Needed? If you have a bad battery of it sits for a long time its nice to have. Check out this thread.
    Yes, you can roll start them.
    As for the larger pegs I don't know because I don't have any. From what I've heard, most people have to modify theirs by doing a little grinding or clipping a spring.
    Stabil or Seafoam isn't needed if you use your gas within a few weeks. I fill up my 5-gallon tank with fuel and add Stabil to it right away. Therefore I have "fresh" gas to use in the bike. Sometimes I add a ounce of Seafoam to my fuel tank, probably once a year. Don't know if it does anything or not, but it makes me feel better.
    The turn signals are flexible to a point. They will break. I've laid my bike down hard and they didn't snap off, but I did break the housing (opposite side of the lens).
    1990 TW200
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    All I would add is that your in Tn. They still sell those seat pads around here. Go to Wally World with the atv and motorcycle stuff and they are rolled up and labeled under the coleman brand.
    Oh and what part of Tn you in?
    Tenaciously Deviant Unwittingly Brilliant
    May 2012
    TENNESSEE
    70
    Rainman, thanks for the detailed reply. That helps me a lot.
    Fort Payne, I am in Maryville.
    Thanks for all the help.
    Revolverman.
    Maryville? You're in dualsport heaven. I hate you.
    First, Complete tune, service, oil change, general nut and bolt tightening with a torque wrench. Make sure the bike is as perfect as can be before worrying about mods. You can download the manuals from the Tech Help forum sticky. Take a couple days to learn the bike.
    Second, sort out the chain and sprockets. The stock chain is junk and will wear quickly, taking out the sprockets with it. This is the only genuine soft spot on a stock TW. An o-ring chain will pay for itself many times over in both money and time invested in chain maintenance.
    Second, consider the batterty. Probably on its third and needing replacement. Due to the cumbersome battery access procedure, consider a sealed battery. If you have the bucks, the Shorai lithium phophates are the way to go. Otherwise, a Chinese AGM will serve you well, <$40 off ebay.
    Though the turn signals are not easily broken, the brake and clutch levers are. Brush guards should be your first priority. A skidplate will protect the cases and covers from being puntured offroad.
    After that, it's personal preference.
    May 2012
    TENNESSEE
    70
    Thanks for the input.
    The owner just put a new battery in.
    He also put nice covers on the clutch/brake. (see photo)
    This bike looks like new to me with only 2500 miles.
    Revolverman.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Quote Originally Posted by Revolverman View Post
    Is it worth it ?
    Revolverman.
    Rainman answered the questions....the larger pegs....some use e-bay bought pegs,9 times out of 10 you'll have to moify them.I used the IMS brand pegs,no modifying...more $$$,yes,but no dicken around.
    Senior Member GapRunr's Avatar
    Jun 2011
    Friendsville, TN
    457
    Welcome to the forum Revolverman.
    I'm also in Murville, off of 6 mile. I've got a shop in Friendsville on 321 just past the Harley dealer called Dual Sport Touring. It's on the left where the speed limit changes to 65mph. I usually have my TW at the shop during the days. If you are in the area some day stop in a say hello!
    GapRunr
    Current bikes TW200 * R1200GS ADV * R80g/s * KLR250 Miami Vice Edition * Hawk GT - For sale!
    May 2012
    TENNESSEE
    70
    Thanks !
    I sure will stop in. I think I picked up one of your cards at All American Insurance the other day. I was wondering about it.
    Revolverman.
    Jun 2011
    Friendsville, TN
    457
    .... I think I picked up one of your cards at All American Insurance .....
    That would be one of my cards all right. Dave at All American Insurance is good people.
    GapRunr
  1. A few questions
    By nfpgasmask in forum General Discussion
    Last Post: 12-10-2012, 01:30 PM
  2. Hi, new here and a few questions about the tw
    By Alanyuen680 in forum General Discussion
    Last Post: 06-06-2012, 06:19 PM
  3. A FEW QUESTIONS
    By HUBJ53 in forum Performance and Customization
    Last Post: 05-10-2012, 04:54 PM
  4. Few questions
    By mjlater in forum Performance and Customization
    Last Post: 02-21-2012, 03:01 PM
  5. Questions
    By shaneatalki in forum General Discussion
    Last Post: 04-24-2011, 03:55 PM
