Identify your T-dub Model Year
Results 1 to 5 of 5
    Member TrailWhale's Avatar
    2007 FZ6 Lancaster, PA
    46
    Simple Suggestion: Please check out the information to the left of this post. I was able to put both the year of my T-dub and my location into the profile area "location" box. Alternatively, the model year can be put into the "signature" block of the profile.
    Either way, it would certainly help forum "experts" to assist with the diagnosis and solving of various problems, if all of us add/indicate the model year of our T-dubs.
    Most problems can be solved with a suitable application of throttle!
    2007 Yamaha FZ6 bagger (still miss the TW200)
    2001 TW200 Yuasa YTZ7-S + Tender Jr.; fuel filter; socket head cap screws for seat; homemade rear rack; D2Moto; carb mods (#128; 3x.01; 2-1/2 turns) (sold 2012)
    1993 XT350 (sold)
    1987 TW200 14/55+Oring (sold)
    et al, et al, starting with 1964 Honda 50 Sport
    Member ktrout01's Avatar
    Bristol, CT
    80
    Great idea !
    1989 TW200
    2003 Triumph Bonneville
    2003 BMW F650GS
    Any commander who fails to exceed his authority is not of much use to his subordinates.
    Arleigh Burke
    Junior Member gdcone's Avatar
    Southern Utah
    18
    Hey TW--could you post a pic of your homemade rack. I just acquired the material (3/8 inch thick wall tubing) to build my own and just wondered about other attempts. I was leaning towards a replica of Yamaha's factory rear rack (under seat and turn signal mounts).
    1976 XL 350 worn out
    1983 CB1100F sold
    2006 TW200 for me
    2007 TW200 for wife-who just sold it
    Jimbo shield for both...
    46
    Quote Originally Posted by gdcone View Post
    Gdcone, my rack is made of 3/4' plywood, on strap steel braces mounted to the same places on the T-dub as the factory Yamaha rack. FWIW, here it is:
    Cyclerack looks like the ultimate solution, but there's a recession going on out there. So I went to Home Despot, grabbed a piece of 3/4" x 48" x 12ga galvanized iron bar stock for under $4.00, and started banging on it with a hammer. First I made a pair of "Z-shaped" brackets which reach under the rear of the seat, to rest on the subframe which holds the muffler. Then I made a pair of "3-bend" brackets which mount on top of the rear turn signals, to tie into the subframe extension which supports the turn signals and rear fender.
    Here's a side view of the four completed, mounted brackets (perhaps not very pretty, but very functional).
    My link
    Here's another view of the completed, mounted brackets. Note that the ends of all four brackets are fastened to the Tdub with the existing hardware, and that the other end of each bracket has a hole for the actual rack to be mounted.
    My link
    Then I added a scrap piece of good quality 3/4" plywood, on top of the brackets, as a base for my top boxes. I'd estimate that the finished rack will hold 30 or 40 pounds, with little problem.
    My link
    Finally, I picked up a small but really rugged shotgun shell case from Gander Mountain and two different sized Sterilite containers from Target to try out as top boxes (all fasten to the plywood base in less than a minute with sheet metal screws, using a battery screwdriver) . The largest Sterilite box is shown here, which basically holds my cell phone, camera, light jacket, sunscreen, water bottles, etc. - - in short, everything but my helmet. I always bungee down the covers. Although none of these boxes are truly watertight, they are at least 95% or 98%. The smaller Sterilite box has already been through a cloudburst, and the cellphone stayed high and dry.
    My link
    Utimately I added a lockable "train case" or "cosmetics case" to the rack, rather than the sterilite box, so I can lock up gloves, light jacket, goggles, etc. while I hike or imbibe.
    1993 XT350 (sold)
    Member dawgs's Avatar
    Aug 2010
    64
    No way am I going to put my bikes year in there. A lady never tells her age.
  1. 1987 Model Year - First Year for TW200's - Good, Bad, Ugly?
    By TW-Brian in forum General Discussion
    Last Post: 01-07-2019, 01:52 PM
  2. How do I tell which year model I have?
    By brah1 in forum Technical Help
    Last Post: 01-11-2013, 06:55 PM
  3. Engine Year Model
    By ldw72120 in forum Technical Help
    Last Post: 10-16-2012, 07:04 PM
  4. Identify Crankcase/Cylinder Part
    By jim1504 in forum Technical Help
    Last Post: 01-16-2012, 06:04 AM
  5. Help me identify this carb mod please.
    By racerx9146 in forum Technical Help
    Last Post: 10-13-2010, 08:36 AM
