what do you use on your O ring chain
Results 1 to 6 of 6
    Member aladdin's Avatar
    May 2012
    Grays Harbor, WA
    33
    Just installed an O ring chain a few days ago. Wondering what product others are using to clean n lube. This is my first O ring chain.
    Senior Member DRF64's Avatar
    Mar 2012
    Kalamazoo, MI
    136
    90 wt gear oil. haven't cleaned it with anything--my bike only has 500 miles on it.
    dan
    Desert, SoCal
    7,369
    90 wt. when I'm home and have the luxury of letting the excess drip off overnight. Cheap house brand ATF when I'm on the road, and for cleaning. I keep it in a small travel size squeeze bottle leftover from contact lense solution. One drop per link every other tank.
    Mar 2012
    Kalamazoo, MI
    136
    do you put your bike up on a stand to oil and clean the chain?
    Desert, SoCal
    7,369
    Cleaning: Seafoam Deep Creep. Raise the rear tire, spray the stuff on, wipe off the thick stuff, second spray carries remaining crud off. Let dry.
    Rust Prevention: Champion Motorcycle Chain Lube. Available at some Walmarts and select chain auto parts stores. Seems to be a modified lithium grease that stays on and does not collect crud. After cleaning, short ride to warm chain. Raise rear wheel and spin chain around, one pass on each set of side plates. Allow to work into the cracks well by spinning rear tire for several minutes. Wipe off excess. Allow to set up. Good for several thousand miles/several months of rust prevention.
    Chain Maintenance Intervals: Street use: 4000 miles or 6 months, along with all other scheduled maintenance. Dirt riding: as necessary.
    Ringed chains cannot be lubricated by the user.
  1. New o-ring chain is on
    By goldenhtr in forum Technical Help
    Last Post: 07-31-2012, 07:35 AM
  2. O-ring chain?
    By mykdee in forum General Discussion
    Last Post: 12-19-2011, 03:11 PM
  3. New O-Ring Chain: Q's
    By bend42 in forum Technical Help
    Last Post: 11-02-2011, 10:14 PM
  4. o-ring chain
    By mrx916123 in forum General Discussion
    Last Post: 07-04-2011, 09:19 PM
  5. Standard vs. O ring vs. X Ring Chain
    By Fishman393 in forum General Discussion
    Last Post: 05-14-2011, 05:46 PM
chain cleaning
