Huge find !
Results 1 to 10 of 14
Thread: Huge find !
    Member Revolverman's Avatar
    May 2012
    TENNESSEE
    70
    Remember in my recent post, "A little concerned ?" I said there had to be a problem with the throttle because I could not give it gas smoothly. It was jerking constantly and causing me to hurt in my neck and shoulders. I could not understand why the throttle was so touchy, so erratic, so hard to smoothly accelerate.
    Well I was at the end of my rope, I knew my age and physical condition had nothing to do with the throttle being so sensative.
    I went to bed last night thinking about all the possiblities..........when it jumped out and bit me like a snake.........CHAIN WAS TOO LOOSE !!!!
    That was it, and after figuring out how to adjust the chain with these new adjustment levers, it was magic !
    100% of the throttle jerking is gone.....smooth as silk, amazing but true. Some may not believe it, but it was instant success.
    I checked the chain with a ruler and there was over 2 inches of slack in it. The book call around 1.3 starting.
    So I moved the setting one whole notch tighter and set everything else and rode it and it was honestly DAY and NIGHT difference !
    I could finally cruise through my yard without these erratic jerking motions from a chain too slack. I was getting jerking accelerating and decelerating.........amazing but true.
    I can not tell you how happy I am to figure this out. I was thinking I was an old man who could not control these new "fangled" throttles and only these younger guys who were skilled in the craft (like I used to be) could operate these new bikes........HA...not so.
    Any way, I rode for 2 hours after this with no neck and shoulder pain.
    I described this erratic jerking from the throttle yesterday in my first post that I erased. It was horrible, there was no control and it was driving me crazy.
    Now I can cruise around and it feels like someone installed a set screw on the throttle. If you want to know how this feels there is a simple way, just loosen your chain so it has 2 or more inches of play. You will not believe how it jerks you.
    Thanks for all the advice......next comes a seat pad and possibly bar lift.
    Revolverman.
    The older I get, the more I realize it's easier to be kind in most situations.
    Senior Member jpuck's Avatar
    Feb 2012
    dayton mt. tn.
    110
    its nice when you can make a adjustment,and problem solved.
    Senior Member mrlmd's Avatar
    1,156
    A really loose chain can jump off the sprocket too, and that can cause all kinds of grief. Glad (for your sake) you figured it out and at least thought to check that, and then got it fixed.
    Senior Member icpchad's Avatar
    Mar 2012
    Yakima, Washington
    152
    Quote Originally Posted by mrlmd View Post
    GREAT to read this.
    Ride Along With Me On YouTube: Hidden Content
    Senior Member MrDNA's Avatar
    Mar 2011
    Aliso Viejo, CA
    502
    If you ride a motorcycle, you have to read Zen and the Art of Motorcycle Maintenance! You can skip the philosophy, but read everything he has to say about working on your own bike. You'll enjoy the work more, and you'll appreciate that the problem is often not where you are looking. You got hung up on thinking it was a throttle problem, which led overlooking the basics. I think he calls it a "gumption trap" in the book, because they kill your self-esteem when you can get it right. Happens to all of us more often than we like to admit.
    Good to hear you got it settled before you had other problems. It's important that you enjoy the ride, so good job on that point.
    Happy trails...
    Something witty...
    2005 & 2010 TW200
    Tennessee
    1,300
    We always run into "gumption traps" and it leaves us a little more prepared for next time. "Zen..." is a good read if you don't even ride, really.
    As well, start putting some money back for fresh sprockets and an o-ring chain. You'll need some other little parts, some of which are optional, but look into it on here to get an idea of what all you'll need. Once that's done, adjust and lube regularly. Once I lowsided a few miles from home when I found some gravel that wasn't there earlier that day. The swingarm flung so hard that the chain came off and I couldn't get it back on in the dark. Had to hide the bike and walk home (before I got on the cellphone boat) with a broken ankle and some gravel in my shoulder. That's chain maintenance for ya.
    6,982
    My service manual says the chain should be between 1.2" to 1.6" of slack. The owners manual says 1.38" to 2.36".
    Another way I have heard of is to line up the center of the front sprocket shaft, the pivot point of the swing arm, and the center of the rear axle. When these three points make a straight line the front and rear sprockets are the furthest apart (apogee?) and you only need about 1" slack at this point and don't worry about how much slack there is at other times.
    Then, just to muddy the waters, there is the philosophy that looser is better than tighter and as long as the chain doesn't come off it is not to loose.
    All I can say for sure is next time around I am getting an o-ring chain.
    Senior Member DRF64's Avatar
    Mar 2012
    Kalamazoo, MI
    136
    Quote Originally Posted by MrDNA View Post
    If you ride a motorcycle, you have to read Zen and the Art of Motorcycle Maintenance! You can skip the philosophy, but read everything he has to say about working on your own bike....
    "skip the philosophy" somewhere I think i heard a scream from my college philosophy prof! Love that advice. I'm going to reread that book just for the motorcycle wisdom. Thanks! I haven't thought about that book in 30 years!
    dan
    Hailey, ID
    3,376
    Quote Originally Posted by DRF64 View Post
    dan
    Me too!! I'll bet it's in the library....seems like I vaguely remember reading it around 1970!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member GapRunr's Avatar
    Jun 2011
    Friendsville, TN
    457
    Quote Originally Posted by Revolverman View Post
    Revolverman.
    I've got the Pro Taper ATV High bars on my TW if you want to come over and sit on it since I am local.
    GapRunr
    Current bikes TW200 * R1200GS ADV * R80g/s * KLR250 Miami Vice Edition * Hawk GT - For sale!
  1. I find this funny...
    By nfpgasmask in forum General Discussion
    Last Post: 10-27-2012, 10:59 PM
  2. where to find parts
    By Tuber in forum Performance and Customization
    Last Post: 09-25-2012, 10:48 PM
  3. CR FIND
    By Plinn2 in forum TW200 Classifieds
    Last Post: 07-18-2012, 07:32 PM
  4. my first tw 87 barn find
    By 2mchprssr in forum Performance and Customization
    Last Post: 06-11-2012, 06:44 AM
  5. A HUGE Thank You!
    By muliefever in forum General Discussion
    Last Post: 01-16-2011, 11:00 AM
