High RPM ?
Results 1 to 10 of 10
Thread: High RPM ?
    Member Kf6rqb's Avatar
    Apr 2012
    Lakewood, CA.
    44
    Post
    I have a 2006 Tw, I put a small RPM meter on my bike, Just wanted to see how high it is running, this is what I found, The bike has stock sprockets and chain-- at 40 mph the rpm is 3300 at 65 mph it is 4400 RPM. The idle speed shows 1400. The bike runs good. I saw some on some post that the tw will run at 9000 rpm, I think that it will blow up at that type rpm. I hope that this info will help someone out. ( just did a oil change,put in a full synthetic 10w 40 oil ,the bike shifts much better now, sounds better too --- )
    Dave A. Smith
    Desert, SoCal
    7,369
    Your tach is off by at least double the rpm. Better have a look at the settings.
    With stock gearing and a new stock rear tire the TW turns in excess of 7600rpm at 60.
    Senior Member DRF64's Avatar
    Mar 2012
    Kalamazoo, MI
    136
    With stock gearing and a new stock rear tire the TW turns at in excess of 7600rpm at 60.
    But 1400 is a normal idle.
    Tennessee
    1,300
    The TW200 has a wasted spark system, so if your meter uses the spark to gauge RPM, you might need to adjust for that.
    Apr 2012
    Lakewood, CA.
    44
    I will look at the box and see that it is set wright. I think that it a cheep unit, I think that I can use the unit to check my rpm's on the low end.
    Dave A. Smith
    Apr 2012
    Lakewood, CA.
    44
    Dave A. Smith
    Mar 2012
    Kalamazoo, MI
    136
    So do we agree that 1400 is a normal idle? Obviously his readings on rpm at 40 and at 65 mph are wrong, but idle is normal, no? I have one of these tachs, and i know from playing around with it when i installed it that there are 3 settings, only one of which is appropriate for wasted spark. but when i had it on the "faster setting," counting every spark, my idle readings were 2500 - 3000.
    and on the half setting, idle was below 1000.
    So....why is his idle normal?
    Were you idling with the choke on?
    dan
    Tennessee
    1,300
    I'm thinking his true idle rpm isn't a healthy one or the unit has gone problems.
    Aug 2011
    Cayce, SC
    3,109
    I believe the manual states that the idling rpm is supposed to be 1300-1500.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Apr 2012
    Lakewood, CA.
    44
    I found that I had it set with the write setting ,I can only get it up to 4500 R P M's. Must be a bad unit , Ten $ on E-Bay , I will use it the way that it is. My idle is at 1400 ,when it is hot 80 deg. At 55 deg. It is at ruff at 1200 R P M's till it warms up. It runs like a new bike now.
    Dave A. Smith
  1. High Fender Pic's
    By Wingnut in forum General Discussion
    Last Post: 09-11-2012, 12:52 PM
  2. high rpm miss
    By greendub in forum Technical Help
    Last Post: 04-18-2012, 05:06 AM
  3. How High Am I?
    By icpchad in forum General Discussion
    Last Post: 04-10-2012, 10:43 PM
  4. ATV High Bars
    By RodneyReed in forum Performance and Customization
    Last Post: 02-09-2011, 08:05 PM
  5. High Idle
    By Henrici in forum Technical Help
    Last Post: 01-28-2011, 01:25 PM
tw200 misses high rpm
