How Much Gas Does The Stock Tank REALLY Hold?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Like Tree113Likes
Thread: How Much Gas Does The Stock Tank REALLY Hold?
    May 2013
    Groton, NY
    2,663
    Filled the TW up today. 1.825 Gallons. Must have been getting close to the "MSR fuel bottle" mode. Anybody ever fill up a bone dry tank?
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member Flathats's Avatar
    Jun 2014
    Idaho
    658
    Yep....walked 2 gal can back out to the alfalfa field...didnt quite take it all...but, I spilled a bit...
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Frosty Hollow
    13,094
    Owners Manual says 1.85 gallons (which would include the reserve). Plus whatever would be left in the line and carb bowl (not much). So, 1.825 is believable.
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    773
    After exhausting computation I came up with 1.8263 US gallons
    Senior Member Elvesus's Avatar
    Jun 2015
    Nanaimo BC
    311
    I'm curious, is the 1.85 gallon (7.0 litre) stated capacity measured from the bottom edge of the filler tube (the 'maximum fuel level')? If so, there should be some bonus room for a bit more fuel for those who live life on the edge and ignore the manual's warning of spillage due to 'overfilling'
    John in Nanaimo
    2013 TW200 - with Shinko 241 front tire, Rox 2" anti-vibe risers, Polisport Touquet handguards, homemade wind deflector, Manracks utility rack
    Apr 2012
    Out West
    3,058
    I've always figured 2 gallons
    "It's Like Warm Apple Pie"
    May 2013
    Groton, NY
    2,663
    Some day I'll purposely run it dry and have my wife pick the bike and me up, run to the gas station, and find out. Should be interesting.
    2013 Yamaha TW200
    1996 Yamaha TW200
    18,841
    Rather than just leaking out the vent tube onto the ground this “overfilling" in a California model can lead to soaking of the charcoal in the emissions canister. Bounce the now heavy fuel soaked charcoal pellets around in their canister on a bumpy trail long enough and they can break down into a clogging sludge.
    My experience was without a reliable vent the engine suffered fuel starvation and subsequent stalling, especially at higher sustained rpms when a vacuum can build up in the tank.
    Apr 2012
    Out West
    3,058
    I install dry tanks fairly often and it takes the entire contents of a 2 gallon can every time - same thing when I use products like metal rescue to remove rust I pour in two full 1 gallon cans and there's room to spare
    Nov 2011
    norcal nutjob
    3,327
    i believe elime poked a small hole into the internal collar and gained .2 gal. not much, but better than walking an extra 1/2 dozen miles.
    here's the post describing the operation: https://tw200forum.com/forum/technica...y-venting.html
  1. Stock gas tank mileage.
    By Ssdyle in forum General Discussion
    Last Post: 09-19-2016, 05:42 PM
  2. 2006 Stock Gas Tank
    By Sstoro in forum TW200 Classifieds
    Last Post: 07-22-2015, 11:26 PM
  3. Stock TW200 gas tank
    By pjenkin in forum TW200 Classifieds
    Last Post: 06-18-2015, 03:05 AM
  4. Wanted Stock 2007 Gas Tank
    By PlacerLode in forum TW200 Classifieds
    Last Post: 10-14-2013, 05:16 PM
  5. Wanted 2008 or Newer Stock Gas Tank
    Last Post: 05-29-2013, 02:35 PM
