Lithium ion battery from China
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Like Tree78Likes
Thread: Lithium ion battery from China
    6,982
    I found this on Ali Express. For about $50 and a 1 to 4 week wait shipping time to the USA this seems a decent deal.
    https://www.aliexpress.com/item/12V-...a-a3f5106211b0
    What special precautions are necessary for a lithium ion battery? I have been using AGM batteries from China in both my TW's and so far they have worked out very well.
    Or buy two of them for $90.
    https://www.aliexpress.com/item/2Pcs...a-a3f5106211b0
    Jan 2017
    Southern Nevada
    1,077
    I know riders that love them due to the smaller size and lighter weight.
    I know riders that hate them for starting in cold weather and dramatic failures.
    For now, I prefer AGM.
    The attached photos were recently posted on the XLForum (XL = Sportster), by Al, from England.
    This occurred immediately after the bike hit a bump on the road and apparently shorted internally.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Mar 2015
    Ynys Môn
    4,591
    There are a few things to look for, mostly “over charge” and “ under charge” protection
    If a lifepo4 is overcharged it fries – if it over discharges it’s dead, and can stay that way
    If it discharges too fast – it fries (big time) – short
    No mention of any of that protection circuitry in the ad – but does say “do not charge over 15v”, which is a little close for comfort
    S’up to you, but you could do better …..
    jtomelliott49 and littletommy like this.
    - Hidden Content
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    770
    I have had no problems with my Lithium battery - I decided to purchase a lithium battery charger with it after doing a lot of research.
    Feb 2013
    Missoula, MT
    908
    AGM for over two years now. It holds a charge very well. Sometimes I haven't started the TW for a month or more and it fires right up. I do not have a trickle charger but I charge it very couple months if not riding.
    A super cheap one. I bought it as an experiment. Lithium is too expensive and to prone to fires, for me.
    18,828
    Funny, I keep hearing assertions that one “needs” a lithium battery charger. Why?
    Both Shorie and Battery Tender’s literature states one is not neccessary, just use any basic trickle charge and avoid any fancy one that has the reverse polarity anti-sulfating pulses. Certainly I charge my Shorie and Battery Tender batteries using the TW’s stator output without any concerns, damage , nor malfunctioning. No need to disable any vehicle’s charging system and use only the “needed” battery tender charger once back home to replace any consumed charge during normal operation.
    Certainly the Battery Tender company would love to sell it’s charger. But they also tell you it is not necessary.
    Senior Member Cornelis's Avatar
    Mar 2015
    Centurion, South Africa
    589
    Gel battery for over two years now, still working perfectly
    1990 Yamaha TW200Hidden Content _____________ Come to Me, all you who are weary and burdened, and I will give you rest. - Matthew 11:28
    May 2013
    Groton, NY
    2,663
    I've got BT Lithiums in all my bikes now. The 4 wheeler has had a el cheapo lithium for 2 years and no problems, even in the cold. The bikes have been less than a year so not much of a test yet. I did the initial charge with the standard BT Junior charger.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Jun 2016
    New Rochelle, New York
    1,774
    AGM in my Softail lasted 10 years on a Battery Tender Plus.
    AGM in my Ural, 9 years and its still a great shop battery.
    Pretty amazing how long they are lasting nowadays. Used to be 3-4 years tops. The Tender definitely helps.
    Took the stock "wet" battery out of the TW and put in an AGM. Didn't see the need or want to buy Li when there is already a great product. And the change in size and weight ain't making the TDub run any faster or better.
    littletommy and jtomelliott49 like this.
    Senior Member Blueduce's Avatar
    Sep 2014
    Central valley Ca.
    209
    elime; I just installed a lith-ion battery in my TW about 2 months ago, the same type as your link. My original 2014 stock battery was getting a little weak.
    I was surprised at it’s weight / size, but so far has preformed flawlessly. There are endless pics and rumors of catastrophic failure of anything on the net.
    I remember a guy telling me he would never use a K&N air filter because a friend of his cousins engin blew up, so I don’t put a lot of stock in the one off failure of a product.
    "Cycles is a mean toy lady" Halsy Knox
  1. Lithium battery replacement?
    By CS1983 in forum Technical Help
    Last Post: 06-12-2017, 01:43 PM
  2. New Battery Tender lithium is dead.
    By centralwarider in forum Technical Help
    Last Post: 05-17-2017, 12:28 AM
  3. New Lithium Battery
    By RickS in forum Performance and Customization
    Last Post: 06-09-2015, 04:50 PM
  4. Replies: 3
    Last Post: 02-05-2015, 11:55 PM
  5. lithium battery issues onTW200
    By kep7790 in forum Technical Help
    Last Post: 09-13-2014, 08:56 AM
news
