gas
Results 1 to 10 of 19
Thread: gas
    Member ridgeline's Avatar
    Jun 2012
    dartmouth nova scotia 2010 tw200
    84
    h igh i am a new member i bought a 2010 tw200 from a lady it only had 500km on it i dont know how to post pictures yet i was just woundering what grade of gas is every one using my bike seems to have a rattling noise when cruising at higher speeds or is that normal i have over 2000km on it now and had the valves adjusted and oil changed at 1200km at the dealer it dosnt seem to make a difference what grade of gas i use thanks
    Senior Member losttourist's Avatar
    Jun 2012
    Ontario Canada
    171
    The manual says to use regular unleaded. At first I was using premium then switched to mid grade for a bit. But now I just
    Use regular unleaded. I have not noticed any difference in performance as to when I first ran the higher grade gas. I haven't experienced the rattling noise on my bike that you mention. What speeds are you going , higher than 100 km/hr ? Also I am
    Running with amsoil synthetic in mine.
    Member matchu67's Avatar
    Mar 2012
    near da beach, FL
    48
    I strictly run R90 Non-Ethanol fuel, no problems and no noises.
    Be safe & Keep on TW 'ing,
    Matt Ward
    - 2012 Yamaha TW200 -
    Senior Member Polarpilot's Avatar
    Iqaluit Nunavut Canada
    422
    All I can get is regular grade. Never have had any issue with it.
    Jun 2012
    84
    Quote Originally Posted by polarpilot View Post
    Jun 2012
    84
    thanks i only travel at 80km per hour i think that is where it starts to red line it did that from the time i first got it maybe im just parienoid
    Aug 2011
    Cayce, SC
    3,109
    Use regular gas. Higher compression engines need a higher grade gas. Using higher octane will do nothing but cost more money with no advantages to regular unleaded in the TW. If you can find non-ethanol 87 that is the money ticket!
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    My bike runs fine in the Florida heat with 87 non-ethanol.However if I do have to run ethanol then I switch to 89 octane. No pinging then.
    Member Herc'sHepster's Avatar
    Jun 2012
    Grants Pass, Oregon
    75
    Thanks Guys!
    I have been running non-ethanol premium but will switch to the regular and remember to get premium when getting "corny" gas.
    1987 Honda FatCat: Custom metalRear fender, aftermarket lights, wood-accented dash
    2011 Yamaha TW200: Jimbo SHeild, Handguards, Factory rack, Hot Wheels barpad
    2013 Kawasaki Brute Force 300: Cleaned of spash graphics, Roll-over scratch accents intact : )B
    Senior Member mrlmd's Avatar
    1,156
    "Premium" is in name only - it has pre-ignition inhibitors in it, is meant for high compression engines, has less energy in it than regular gas, and will actually deteriorate performance and gas mileage in a low compression engine like in the TW. It is totally unnecessary for these bikes to use premium fuel, unless you want to go faster from a lighter wallet. "Premium" does not mean it is "better" than regular, only that it's formulated for high compression high performance engines that may knock with regular gas.
pinging tw200
yamaha tw200 gas grade
