Is hauling one TW on a two bike trailer smart
Results 1 to 10 of 14
Like Tree25Likes
Thread: Is hauling one TW on a two bike trailer smart
    Senior Member Cascade Rider's Avatar
    Sep 2017
    Kent, Washington
    123
    Looking for a TW and considering ways to carry it. If I choose a trailer built for two bikes (bringing a friend's along) but somedays only carrying mine, is it an invitation for trouble? Or should I consider a three place trailer and center my bike on solo trips?
    littletommy likes this.
    God made mud. God got lonesome. So God said to some of the mud, "Sit up!" "See all I've made," said God, "The hills, the sea, the sky, the stars." And I was some of the mud that got to sit up and look around. Lucky me, lucky mud. I, mud, sat up and saw what a nice job God had done.
    Kurt Vonnegut, Cat's Cradle
    May 2013
    Groton, NY
    2,663
    I would buy a regular utility trailer big enough for 2 bikes. That way you could haul 1 in the middle, 2 side by side, or use the trailer for a run to the local home improvement store.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Pleasanton, CA
    5,747
    It is hard to say for sure without knowing the specifics of the trailer that you are considering. I have a small two place motorcycle trailer on which the right side channel is slightly offset towards the center of the trailer to somewhat compensate for when only one bike is being trailered. So unless the trailer is very narrow, very lightweight and has very small donut sized wheels, I would not worry too much about trailering only a single TW.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Quote Originally Posted by scotti158 View Post
    This, AND, add holes for wheel chocks that you can place as needed.
    scotti158 and littletommy like this.
    Jun 2016
    New Rochelle, New York
    1,775
    I can't speak to other brands of trailers but when I first bought my Kendon dual trailer one of the first thing I bought was the Center Rail Chock for hauling a solo bike.
    Big surprise to me was that Kendon sternly recommends NOT to do this. The 3rd/extra rail is for hauling 3 bikes (obviously smaller dirt bikes) and not a single.
    With torsion-bar suspension it is engineered to hold one bike by itself on either side. It really is a mind-freak initially doing this because if you look at it... well... it just doesn't seem to make sense.
    But it does work very well/perfectly this way. Really makes no sense to buy a single trailer for any motorcycle. They'll always be someone or some other bike to haul. I have a carrier now to. But sometimes the trailer is just as easy to layover in the garage and haul one bike.
    I'm usually hauling two bikes but one is not out of the question. Funny thing is that because you have to drill some holes in the trailer to install the 3rd rail, I never had done so. Was never going to use it they way I thought I could.
    Even at 500 lbs. the trailer (at least this brand and suspension) does not lean at all. Kinda mind-boggling!
    I don't leave the VersaHaul together so when I'm going to use it I have to "build" it. That and it's weight (it's darn heavy) sometimes makes just using the Kendon an easier hook-up.
    Cascade Rider and Fred like this.
    Feb 2017
    Waretown NJ
    556
    Can't say whether it's smart, but I've done it a million times with my bikes.
    I now have a well used harbor freight trailer. I cam put the bike anywhere. It's Chinese, it's cheap, and one of the most useful things I've ever bought
    Cascade Rider likes this.
    87 TW
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,094
    Just be mindful of the weight capacity of what ever trailer you do decide on. A single TW weighs right around 300 pounds so 2 TWs would be 600. A trailer with a 1,000 or 1,200 pound capacity would be most suitable for this load. My utility trailer has a 3,500 axle and sucks for carrying just one light bike or garden tractor because it bounces all over the place. I built one of the Harbor Freight El Cheapo trailers and I did beef it up a bit and love it. I would not recommend it for long hauls but for minor short distance hops it is perfect and with a 3/4" treated plywood floor you can add and remove any chocks and eyelets as needed. For around $300 and a days assembly time you can't beat it for a TW or in my case a couple kayaks.
    1987 Yamaha BW350 Big Wheel
    6,985
    I have a two motorcycle trailer, home built I think, and I haul one TW on it all the time. I have had zero troubles doing it, even doing 70+ mph.
    admiral, littletommy, Mel and 1 others like this.
    Sep 2017
    Kent, Washington
    123
    A commendable job on that trailer. I see from one picture you haul your bike on one side of the trailer. Any issues there?
    Apr 2014
    985
    OK Cascade Rider; I know a picture is worth a thousand words - but if you go back and ignore the pictures, you'll have your answer
  1. Replies: 4
    Last Post: 05-04-2016, 04:28 AM
  2. custom dog hauling trailer $2500 o.b.o.
    By Fred in forum TW200 Classifieds
    Last Post: 10-26-2014, 01:16 PM
  3. Starting another bike hauling thread.
    By srs713 in forum General Discussion
    Last Post: 03-30-2014, 03:49 PM
  4. Trailer for back of bike
    By Trailerpark in forum Performance and Customization
    Last Post: 09-18-2012, 11:52 AM
  5. Hauling the bike on truck
    By cool breeze in forum General Discussion
    Last Post: 07-31-2011, 12:46 AM
