Looking for TW Engine!
Results 1 to 9 of 9
Like Tree26Likes
  • 1 Post By tlanth1985
  • 1 Post By Badgerflorida
  • 4 Post By Tweaker
  • 3 Post By TW-Brian
  • 3 Post By Purple
  • 3 Post By littletommy
  • 4 Post By maddawgj
  • 3 Post By elime
  • 4 Post By Fred
Thread: Looking for TW Engine!
    Junior Member tlanth1985's Avatar
    Nov 2017
    1
    Hey all,
    First time poster here. I have a 1989 TDub that the motor is seized up. Anyone have any leads on a replacement motor? Tried Ebay, nothing really standing out.
    Thanks!
    maddawgj likes this.
    Jun 2017
    Milwaukee, WI
    1,284
    Welcome. Sorry I can’t help. But if anyone has any leads, this is the place. Good luck with your search. I believe some here have fitted bigger engines (XT225). I’m sure it required mods, but could substantially increase your options. And if it’s not a basket case, yours might be rebuildable. Cheers
    littletommy likes this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Dec 2015
    San Diego
    1,864
    Did you see this one on the classifieds?
    https://tw200forum.com/forum/tw200-cl...6sp-motor.html
    littletommy, Fred, Peterb and 1 others like this.
    Pleasanton, CA
    5,745
    Welcome to the forum!
    Where are you located?
    Mar 2015
    Ynys Môn
    4,591
    Welcome to the house of fun
    You may wish to replicate your post in the "Classified" section for the best results - it's for buyers and sellers - and would maximize your reach to members
    We'll leave it sitting here as well - good luck with your search ....
    - Hidden Content
    Spokane, Washington
    17,398
    Welcome!!
    Badgerflorida, maddawgj and Purple like this.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    Pull the spark plug and pour an ounce or two of Murphy’s Mystery Oil in the spark plug hole and give it a couple hours to a day to seep down. Then try to get the engine to turn over again.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    6,982
    Why did it seize? Is it from sitting for a long time without use? Then do the Mystery Oil trick. If that doesn't work take of the head and gently tap on the pistons. Chances are only the rings are stuck.
    If it is from over heating / lack of oil , take it apart and if the upper end of the rod is OK then maybe you can get by with a new piston and used cylinder.
    Ken, Badgerflorida and maddawgj like this.
    18,824
    Forum members here seem to rebuild more often than replacing damaged TW engines. Repairing is usually not too expensive nor difficult. Somewhere here someone has fixed darn near everything that can go wrong with these motors. So archival as well as current help is available. Maybe share more details of original engine’s failure?
  1. Replies: 7
    Last Post: 10-24-2014, 07:51 PM
  2. I think i've got an engine problem....
    By Hikerglenn in forum Technical Help
    Last Post: 09-20-2014, 11:29 AM
  3. I might of ruined my engine
    By 1RobAusdemore in forum Other Bikes
    Last Post: 09-13-2014, 12:36 AM
  4. If it has an engine we have a race.
    By arrowsmith in forum Off-Topic
    Last Post: 05-19-2014, 06:30 PM
  5. Value of the engine?
    By Frank Colver in forum General Discussion
    Last Post: 02-24-2013, 02:02 PM
Tags for this Thread
