Sprocket size;s on a stock 2010 TW 200 and fabrication of a rear rack ??
Results 1 to 5 of 5
Like Tree11Likes
  • 3 Post By excalibur
  • 2 Post By Purple
  • 2 Post By maddawgj
  • 2 Post By littletommy
  • 2 Post By troll
Thread: Sprocket size;s on a stock 2010 TW 200 and fabrication of a rear rack ??
    Senior Member excalibur's Avatar
    Nov 2017
    La Center, WA
    118
    Can anyone with an answer tell me the stock front and rear size of my two sprockets ?
    Also, having 5 trail 90's ( 2 of which are strickly parts bikes and a ct 110, I have many spare parts including the small auxillary ( sp?) gas tanks and brackets as well as a couple extra rear racks.
    Has anyone here modified one of the later honda trail 90 racks to fit their TW and do you think it advisable to mount a gas can bracket from a fabricated and somewhat extended saddle bag bracket on the left side to be able to carry spare gas that way? I would be mounting it as far back as possible on the left side, just behind where I think my saddle bags would be located...
    I have been a certified welder for over 35 years even though I'm retired at this point. I have came up with some awesome fabrications over the years and still have a 220 Lincoln wire feed welder as well as my torch and tanks, hand and bench grinders and a large water/oil bath band saw.
    Basically I have about everything I think I need to fab up a rear cargo rack using one of the strong already built trail 90 rear cargo racks and fabricating my own removable side racks for use with saddle bag and the spare Honda gas container with a locking securement bracket from a doner T-90 as mentioned above for long backwoods trips where camping gear and spare gas would be a big plus.
    Thoughts on the feasibility of such a rack ? Or should I go with something like ones built by cycleworks ?
    Thanks for any feedback,
    Gene Carroll
    maddawgj, littletommy and TW-Brian like this.
    2010 TW 200 Dual Sport
    2017 Harley Softail Slim w/110 Cubic Inch Screamin' Eagle engine
    2005 Yamaha 450 Kodiak 4x4 Quad
    Mar 2015
    Ynys Môn
    4,594
    Stock sprocket sizes are 14/50 or 14/49
    If you copy and paste this - rear rack site:tw200forum.com - into google, you will have all the info you need, and more advice than I could give, or list .....
    maddawgj and littletommy like this.
    - Hidden Content
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    There have been been plenty of cut and rewelded racks off of other bikes (or ATVs) modified to fit as well as plenty built from scratch. Cycleracks uses schedule 40 tubing for strength to give you a material reference. Personally I like to build from scratch unless I’m modifying something that has history to keep it. Your call.
    littletommy and troll like this.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Spokane, Washington
    17,422
    Your a fabricator, build it.
    troll and maddawgj like this.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member troll's Avatar
    Nov 2013
    frozen wasteland of the barren north, Yukon Territory, Canada
    1,204
    Took the words right off my keyboard...... all the tools and 35 years worth of skills.... Unless one does not like design, fabrication and welding anymore
    littletommy and maddawgj like this.
  1. Which rear rack and why? Newby with stock TW200
    By Jduncan740 in forum TW200 Pictures / Videos
    Last Post: 06-20-2016, 02:36 PM
  2. Front/Rear Sprocket Size Change Effects
    By Darth in forum Technical Help
    Last Post: 01-31-2016, 02:26 PM
  3. Replies: 2
    Last Post: 09-14-2013, 07:04 PM
  4. good replacement chain for use with stock sprocket size
    By grt1982 in forum Technical Help
    Last Post: 07-11-2011, 05:07 PM
  5. Rear Sprocket Bolt Size
    By Rezolution in forum Technical Help
    Last Post: 04-06-2011, 11:21 PM
