4 piece crutch jack
Results 1 to 10 of 11
Like Tree8Likes
Thread: 4 piece crutch jack
    May 2012
    Tucson, AZ
    976
    Made this tonight with nothing more sophisticated than a hacksaw, a decent file, and the input of a pretty dang smart woman.
    Cobbled together from 2 crutches purchased for $5.00 from the local goodwill.
    My initial plan was to make a 2-piece sliding assembly that could be adjusted by several inches, but the little lady observed that by shortening one sleeve and using the shortened snap-button ends of both crutches I could have a lot more range in 4 pieces than 2 with less overall compressed length for storage. I knew there was a reason I married that gal!
    There's a lot of variation between sets of crutches, but these were originally made for a very tall person. Here's what's left of them:
    Short adjusts to 11 5/8, 12 5/8, 13 5/8, or 14 5/8
    Long adjusts to 16 3/4, 17 3/4, or 18 3/4
    And all 4 pieces disassembled
    The shorty ends clicked into the short sleeve and the 11 3/4 extension both pack away at less than a foot, so you get a lot of range in a jack stand in a pretty compact package. I'm, er, the wife probably isn't the first to come up with this, but I thought it was worth sharing just in case.
    Here's hoping none of us ever need one out on the trail!
    JohnJohn, Dryden-Tdub and Tweaker like this.
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Pleasanton, CA
    5,747
    Thanks for the great tip! I've been watching craigslist for awhile trying to snag a pair of crutches, but so far no luck. When I do find a pair, I'll use your suggestion.
    Brian
    May 2012
    Tucson, AZ
    976
    Brian
    As long as we're swapping tips, What exactly do you have going with that low-pro topcase? I've been admiring that for awhile and thinking about ordering a cycleracks rear rack and putting something similar together for myself.
    2012 KLR650
    - Sold
    Pleasanton, CA
    5,747
    The following storage tube link details how I originally mounted a Pelican case directly onto the rear fender (starting at post #36).
    https://tw200forum.com/index.php?/top...e/page__st__30
    That arrangement worked well for light duty service for about 1,000 miles or so until my son dumped the bike on the left side and then I dumped it on the right side. I now have a rear Cyclerack with the case/storage tube arrangement mounted to that and it is rock solid. Unfortunately I don't have any pictures of the current mounting. Let me know if you are interested and I'll take some this weekend.
    Desert, SoCal
    7,369
    Brian
    Thrift stores are usually littered with them for a few bucks a pair. Try the Salvation Army, Goodwill, etc.
    Tweaker likes this.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    Second hand/thrift stores that are frequently run by various organizations (charitable) are frequently over-run with crutches and those adjustable walkers. I attached a piece of contoured channel to the top of my jack. With this, it will embrace the swing-arm snugly and does an 'ok' job of holding the fork by engaging the hole in the bottom of the fork tube. I have used mine to go through the motions of a practice rear tube repair. Gerry
    Don, you put together a pretty nice unit, hope you don't mind my additions. The jacks are indeed, very handy. Boy Russ, don't tell me you while away the hours in thrift stores as well. One of my local favorites is the "Senior Center" store. There I can get a discount on 'walkers'. Gerry
    Mel likes this.
    Take care my Friend.........
    Desert, SoCal
    7,369
    Great minds shop alike
    Jun 2014
    Bel Air Maryland
    4,169
    I was interested in buying the SnapJack V2 off Amazon when I discovered this Thread. I happen to have a set of crutches
    Tweaker likes this.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Hailey, ID
    3,376
    I've had mine for 6 years now, makes lubing the chain a snap.
    tuna and TopPredator like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Jun 2014
    Bel Air Maryland
    4,169
    The SnalJack V2 is a pretty nifty jack.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
  1. Trail Jack
    By r80rt in forum Technical Help
    Last Post: 07-21-2013, 10:37 PM
  2. What is this little piece?
    By zoolander in forum Technical Help
    Last Post: 05-19-2013, 07:29 AM
  3. Stand or Jack?
    By nfpgasmask in forum Technical Help
    Last Post: 09-25-2012, 09:52 PM
  4. The crutch
    By mekdad in forum General Discussion
    Last Post: 01-12-2012, 07:53 AM
  5. Roadcrafter 1 piece Hi-Viz/grey ballistics size 46L
    By neve_r_est in forum TW200 Classifieds
    Last Post: 07-06-2011, 07:11 AM
craigslist crutches
crutch jack
crutch jack motorcycle
crutch trail jack
crutch-jack
ideas for old crutches
trail jack tw200
