Base Gasket Leak
Poll: Repair or Live with It?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 10 of 13
    Member bogey72's Avatar
    Aug 2012
    North Alabama
    70
    Let's hear it.
    Aug 2012
    North Alabama
    70
    2005 with 2000 miles.
    I have just a little oil leak and I think I'll ride it for awhile and see if it worsens. Of course, I'll check my sight glass often.
    Germany, Werdau
    1,014
    I don't have this problem.
    I use Athena gaskets for my engines and I recommend it for my customers.
    The question is, where is the oil leak?
    Does the oil came from the cylinder base or from the oil line to the cylinder head?
    In my opinion, the cylinder base gasket in NOT the problem.
    The sealing against the engine oil is not the cylinder base gasket. The o-rings are doing this job.
    Both problems (oil from the cylinder base or from the oil line) can be solved by some new o-rings/rubber rings.
    The original cylinder basket o-ring is 70 x 3 mm and the oil line o-ring is 12 x 2.5 mm.
    If you still have the same problem, than you should use bigger o-rings.
    cylinder basket o-ring: 70 x 4 mm
    oil line o-ring: 11 x 3 mm
    Regards, Sebastian
    Germany
    Senior Member Larry's Avatar
    158
    I asked this once and the explanation I got was that it seems to come from the rectangular area that the timing chain resides in and not from the cylinder because an oring is located there.
    So basically the oil comes from that area and then appears as though its coming from the cylinder. When actually its coming over from the timing chain area and leaking out as thought coming from the cylinder.
    Mine has been leaking for 2000 miles and I have 3500 total now. Just watching it and plan on replacement this winter.
    Quote Originally Posted by macbig2k1 View Post
    Regards, Sebastian
    Germany
    2008 TW200 - Jimbo W/S, Rear Cycle Rack, Magnetic Drain Plug, Wally World Seat Cover, Custom JB Welded Seat Screws. (Desires - Kicker, Raised Handlebars, and Round Headlight)
    Mar 2011
    Gobles, michigan
    1,824
    My 06 with 9,000+ miles has a verrrrrrrrrrrrrrrrrrrrrrry slow leak, so I just wipe off as needed.. Same with my wife's 06.... I bought new 2010 gaskets but have not bothered to put on.OMM.
    6,982
    This is what it looks like just shy of 100 miles. I will ride another 100, maybe 200, before I bother to wipe it up.
    It is an '87 with almost 19K miles on the odo.
    Gooey crap is Permatex Spray On Sealant. I think it slowed the leak a little but sure didn't stop it.
    Member dmathia's Avatar
    Jun 2011
    North Central Florida
    58
    I replaced the o-rings and gaskets at 3500 miles on my 07, I'm a retired mechanic and couldn't stand it any longer. It's my opinion also that the problem is more the o-rings than the gasket. Have gone 5k since then, no leak. I used the original style gasket, the newer one wasn't available at the time.
    07 Tdub - Jimbo shield, Givi carrier, 14/45 gears, O-ring chain, Tusk guards and risers, big pegs, seat pad, 45oex tip, Ultra H4, LED rear lites, fuel filter, dual horns, foam grips, storage tube, AGM battery.
    Jun 2011
    Dothan, AL
    1,715
    My 2005 started leaking at about 5500 miles, same time I switched to synthetic 10-40, it was leaking pretty good that I had to wipe it every day. At 6500 miles I went back to dino 20-50 and the leak stopped, now at 7200 and still no leak. I'm not saying it is the oil but that is my observation at thIs time. I can not remember off the top of my head what brand of oil, but it is that popular one sold at Wal Mart. Like RT 4 or 4T something like that.
    2005 TW200 (SOLD)
    2013 DR650
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Quote Originally Posted by n2o2diver View Post
    Great insight. Things I've read about synthetic tends to backup your observation.
    On a recent thread, after the base gasket started leaking a member of this forum checked and found head and cylinder bolts loose. He re-torqued them and the leak went away. On another thread the same thing happened, but the guy over-torqued just a couple of the bolts and it made the leak worse. So, if I were to get another base gasket leak I think I would re-torque to specification all the head bolts using the head bolt torque pattern to ensure even pressure on the head and cylinder. I would also re-torque to specification the bolts at the base of the cylinder that hold the clutch cable mount.
    If, after re-torquing the fasteners it continued to leak, I would replace the base gasket and associated o-rings. If you have any mechanical experience at all It's not that hard or time consuming. With no experience I believe it's still do-able by following directions and maybe getting a little help.
    I respect other's experiences and opinions, but my experience has been that the version of base gasket does make a difference. The first time I did my base gasket the parts person led me to believe the newer part number for the base gasket would supersede the older part number. I was in a hurry (first mistake) and didn't confirm by part number that I had the newer style base gasket. I know, pretty dumb of me. I did replace all the o-rings at that time. In less than 2,000 miles it was leaking again. On the second time around I simply ordered all the parts for a 2010 TW. With about 1200 miles on it now, it's as dry as a bone.
    With such a variety of experiences it's hard to nail down exactly what's going on. We know from the o-rings that the oil feed to the head is around the right rear head bolt. Since the oil is under pressure there you would think that would be where the leak occurs. But I've never seen or heard of the leaks occurring there. In my experience it's always been on the left side of the cylinder around the timing chain cavity.
    I don't remember seeing an oil flow chart, but believe at least some of the oil from the head returns through the timing chain cavity to keep the timing chain lubricated. I believe the action of the chain spinning flips the oil around some and this is what causes it to migrate through the most poorly sealed area of the crankcase/cylinder junction. The timing case is also open to the spinning crank and gears. As others have pointed out, other areas of the cylinder are well sealed due to the use of o-rings. The addition of beads of sealant on the newer version of the base gasket tends to act as an o-ring to better seal the area around the timing case.
    Well, as you can see there is a lot of supposition going on in the 2 previous paragraphs, but it's my theory and I'm stickin' to it , at least until you guys correct me.
    Jun 2011
    58
    There is also an o-ring around the cylinder base. I would have preferred the new gasket, but I guess I'm lucky.
  1. Base Gasket Leak Questions
    By jwashkau in forum Technical Help
    Last Post: 06-14-2013, 09:55 AM
  2. Base gasket leaking
    By sensor419 in forum Technical Help
    Last Post: 03-27-2012, 09:07 PM
  3. 07 base gasket leak
    By small's in forum Technical Help
    Last Post: 03-25-2012, 09:41 AM
  4. New base gasket reviews
    By kennethshaw in forum General Discussion
    Last Post: 05-11-2011, 06:10 AM
  5. Base Gasket Leak Question
    By lonedave in forum Technical Help
    Last Post: 04-26-2011, 02:49 PM
04 tw 200 oil leak
2010 yamaha 200 4 stroke oil leak
base gasket sealed but still leaking
gasket kit
is an oil leak on a 1995 yamaha tw200 a major fix
repair cost base gasket tw200
tw200 base gasket replacement
tw200 basket oil leak year
tw200 cylinder base gasket leak
tw200 forum
tw200basegasketleaks
yamaha tw200 oil leak
