What is your favorite tube for the tdub and why, what size?
Results 1 to 7 of 7
Like Tree15Likes
  • 3 Post By Ken
  • 1 Post By ejfranz
  • 2 Post By admiral
  • 3 Post By Ken
  • 1 Post By joeband
  • 3 Post By Fred
  • 2 Post By Maxpower
Thread: What is your favorite tube for the tdub and why, what size?
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,933
    Now that I have received my tires, now I need tubes. I have switched tubes from tire to tire over the years. I believe it is time to change them. What are your recommendations?
    Feb 2015
    Maple Ridge, BC, Canada
    1,560
    I buy whatever is available. I have had heavy duty and el cheapo. Both have worked fine for me.
    Badgerflorida likes this.
    Frosty Hollow
    13,095
    Only have bought stock tubes. With you're new street oriented tires I presume you ride mostly pavement. I would think stock tubes would be fine for you unless you have to run over a lot of Armadilloes.
    ejfranz and maddawgj like this.
    Aug 2016
    Houston, Texas
    1,933
    I prefer the heavy duty but all I really see in the TW size is Bridgestone or Michelin. I guess I'll get the Bridgestone since they are still holding air. I don't think I ever changed the rear tube which would make it over 20 years old. I haven't seen many armadillos in a while. We use to chase them and catch them by the tail. They run under everything you have to go over or around. I'll have to see if I can get some armadillo pics.
    ejfranz, admiral and maddawgj like this.
    1993 TW200 just over 46,000 miles
    Nov 2011
    norcal nutjob
    3,329
    my eyes must really be getting bad, i didn't see the crossbar on the T in tube and thought this was another Lube thread... not needed to see more "natural and water-based." i've generally used heavy duty, and only had one flat, a nail that would've taken out tube short of one filled with ride-on.
    maddawgj likes this.
    18,845
    Any tube as long as I add RideOn sealer and balancer.
    jtstdub, maddawgj and ejfranz like this.
    Feb 2017
    Waretown NJ
    556
    the TW wheels are heavy enough. Adding weight with HD tubes I don't feel is a good thing.
    But if you ride in a area that you need them not to flat out then heavy wheels are better than flat wheels
    littletommy and maddawgj like this.
    87 TW
  1. Correct tube size?
    By DanBarwick in forum Performance and Customization
    Last Post: 05-31-2016, 06:18 PM
  2. TW tube size?
    By retro in forum Technical Help
    Last Post: 06-25-2013, 08:42 PM
  3. Front tube size
    By JerryW in forum Technical Help
    Last Post: 02-07-2012, 03:06 PM
  4. Rear tube size
    By azwheelin in forum Technical Help
    Last Post: 07-14-2011, 02:30 PM
  5. Front Tube Size??
    By Quicksand in forum Technical Help
    Last Post: 11-25-2010, 12:44 PM
