Wheel Options
Results 1 to 10 of 10
Thread: Wheel Options
    Senior Member nfpgasmask's Avatar
    Nov 2010
    Reno, NV
    500
    Hi folks, well, I am getting closer to starting my custom TW200 project. I have starting wondering about wheel options. Given that the TW200 has very particular tires, are there any aftermarket wheel options that will work? I am not dead set on changing the wheels, but I really like mag wheels like these:
    Are there any options? Is there a specific wheel size I should look for? I am thinking there isn't much in the way of options for changing out the wheels while keeping the fat rear tire, as I have never seen custom wheels on a TW.
    Thanks - Bart
    Senior Member dganey's Avatar
    Oct 2010
    SE Michigan
    342
    procycle.com has supermoto wheels for the tw. Pricey though.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Quote Originally Posted by dustyg View Post
    Good info!.
    Germany, Werdau
    1,014
    I've just found this site:
    http://www.procycle.us/bikepages/tw200.html
    But there are no supermoto wheels.
    Senior Member DRF64's Avatar
    Mar 2012
    Kalamazoo, MI
    136
    Quote Originally Posted by macbig2k1 View Post
    http://www.procycle....ages/tw200.html
    Actually the bridgestone tw203/204 and the Shinko SR428 are basically street tires. They look supermoto to me. Not a lot of other options for the tdub.
    dan
    Germany, Werdau
    1,014
    That is not 100% correct, there are many tyre options (direct made for the TW) available (should be a complete list):
    - Bridgestone TW32/34
    - Bridgestone TW203/204
    - Dunlop K180
    - Shinko SR428
    - VeeRubber VRM274/VRM275
    Back to topic -> Wheel Set for the TW <-
    From my experiences, there are no other wheels easy to fit in ("plug'n'play").
    You have to make for every other wheel set spacers and adaptors.
    Regards, Sebastian
    Nov 2010
    Reno, NV
    500
    That's what I thought, thank's guys. The bike in my pic at the top is a Yamaha SR500, and I think those wheels are just stock SR400/500 wheels powder coated black. I figured since I have never seen any other wheels on a TDub options must be nil...
    Bart
    Mar 2012
    Kalamazoo, MI
    136
    - Dunlop K180
    - Shinko SR428
    4 options other than stock is not many. I would also say the Shinkos and the Bridgestone 203/204s are similar enough to be counted as one choice. I'd say both tire and wheel options are limited.
    Senior Member Trikstr's Avatar
    Jun 2012
    Oak City, UT
    156
    Wheels= metal things
    Tire= rubber stuff
    '99 TW,Ricochet skid plate, Seat Concepts, Jimbo shield, 2" extended swingarm w/Maxxis Bighorn, 5.10 Kenda K270, Stealth exhuast, YZ80 hybrid front forks w/HyperPro proressive springs, ProCycle high mount front fender, ProCycle wide foot pegs, TT-R stainless head pipe, Lizrdbrth cooler, D-Flex hand guards, XT350 gas tank.
    2002 Honda Spirit Shadow VT750
    1987 BW350
    '78 Honda XL100
    918
    Buchanan's can custom drill aluminum rims to match the hub, spoke count, and spoke angle. It's not cheap, but if you wanted something completely custom, that'd be it. You would not retain the 14" rear, you'd need to step up to a 17" or 18" rim. Tires won't be AS wide as the 180 the TW has, but you can get close with 150's/160's. Get's you in the supermoto rim sizing and tire options.
    http://www.buchanans...uminum_rims.asp
    It's an option to look into, but, obviously, they are not mags.
    Some guys do put mag's on the drz's, yzf's, etc. They get them off older sportbikes (cbr's) as the older ones' wheels aren't as wide as the newer ones (the drz's swingarms can only take so wide of a wheel). With the TW you could probably try going for the newer, wider ones as the swingarm of the TW should allow it, but tire choices would be limited to street tires for sportbikes. It takes some work and with a TW you'd need to solve the difference in axle diameter, but here are some examples of that:
    http://motard-superm...tsontheweb.net/
    http://www.thumperta...-on-an-drz400s/
    http://www.thumperta...s-on-my-yz426f/
    Sold bike.
  1. Should I keep my options open?
    By stephenmarklay in forum General Discussion
    Last Post: 03-24-2012, 06:14 PM
  2. tank bag options
    By peruano in forum General Discussion
    Last Post: 02-08-2012, 02:02 PM
  3. TENT OPTIONS
    By ronnydog in forum Trails, Off-road, and Adventure Riding
    Last Post: 01-08-2012, 10:59 AM
  4. Footpeg options!
    By yamamont in forum Performance and Customization
    Last Post: 11-11-2011, 11:59 PM
  5. ATV Tire options
    By jefmtbkr in forum Technical Help
    Last Post: 01-20-2011, 02:53 PM
custom tw200 tires
rear tire options for tw200
rear wheel options for yamaha tw 200
tw200 aftermarket wheels
tw200 rear tire options
tw200 supermoto
tw200 tire options
tw200 wheels
yamaha tw200 rear tire option
yamaha tw200 rear tire options
yamaha tw200 supermoto
yamaha tw200 tire options
