SHINKO SR241 Tire Pressures
Results 1 to 7 of 7
Like Tree29Likes
  • 4 Post By maddawgj
  • 6 Post By Dryden-Tdub
  • 4 Post By Tweaker
  • 4 Post By ejfranz
  • 5 Post By RockyTFS
  • 4 Post By westcoasting
  • 2 Post By maddawgj
Thread: SHINKO SR241 Tire Pressures
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    Hey 241 users, what tire pressures do you use for street/trail? Thanks.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Apr 2014
    Dryden NY
    6,343
    Quote Originally Posted by maddawgj View Post
    I like 18 lbs on or off road. Too much air in the 241 seems twitchy on the pavement. Trial and error.
    Tom
    Dec 2015
    San Diego
    1,864
    12-14 lbs front around 10-12 in the back. I weight @165 lbs. I am lazy and usually don’t air it up for pavement unless I know I will on the stret a long time.
    Feb 2015
    Maple Ridge, BC, Canada
    1,560
    For technical trails drop to around 8 psi.
    Hailey, ID
    3,377
    12 in the dirt (maybe 10 if real soft with no rocks), and 18 on pavement, if i'm going more that 10 miles or so. I take the OEM rear down to about 14 in the dirt, maybe 16 if it's real rocky.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Member westcoasting's Avatar
    May 2016
    76
    On road 18 seems good... i don't ride much on pavement though. Off road 10 with a extra heavy duty tube i really like.
    May 2012
    445
    Quote Originally Posted by Dryden-Tdub View Post
    I like 18 lbs on or off road. Too much air in the 241 seems twitchy on the pavement. Trial and error.Tom
    Yes it does.
    littletommy and Badgerflorida like this.
  1. Easy one - Tire pressures to start with....
    By GCFishguy in forum Technical Help
    Last Post: 05-14-2017, 07:37 AM
  2. Installing new tires: Shinko SR241 and TW34
    By sjh953 in forum Technical Help
    Last Post: 09-16-2016, 06:52 PM
  3. Replies: 8
    Last Post: 06-15-2015, 06:58 PM
  4. Replies: 0
    Last Post: 06-15-2015, 03:10 PM
  5. For those that have a Shinko SR241
    Last Post: 05-19-2013, 02:05 PM
