Why did Yamaha Build the TW200?
Results 1 to 10 of 19
Like Tree1Likes
Thread: Why did Yamaha Build the TW200?
    Junior Member Irishguy's Avatar
    Sep 2012
    Birmingham,Al
    18
    I have been thinking about this every since I have owned this bike. Why did Yamaha build the TW200? The easy answer is that it's a trail bike, but every other manufacturer builds dual purpose, enduro, trail riding bikes, but none of the others have the big tires like the TW. Was there some kind of specific purpose that Yamaha had in mind when building the TW? Agriculture? Hunting?
    I realize the bike has a cult like following, and I love mine already, but we all have to admit it is a bike that is a little bit different. There must have been an original reason for it.
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by Irishguy View Post
    While certainly not a definitive or authoritative review, Motorcycle Specifications did a fairly nice job of describing the T-Dub and giving a bit of history at http://www.motorcyclespecs.co.za/mod...tw200%2089.htm - here's what they say:
    Introduction
    Being referred to as “Yamaha dirtbike on steroids”, this odd beastie is a versatile machine usable on any kinds of terrains but most of all, ridden by any kind of rider. The term “workhorse” might not be the best way of introducing a motorcycle, but it does sum up the TW200 perfectly. Officially labeled as an “agricultural machine” it is also the preferred choice for weekend trips with many finding the TWs unthreatening package the perfect family companion.
    1991 Yamaha TW200
    This is a great little bike with a rich historic heritage.
    The TW200 Adventure Trailway appeared in North America in the early Eighties and was launched on the Japanese market in 1987 when Shinji Kazama reached the North Pole on it. It was equipped with a 196cc 4-stroke single cylinder engine that already could be found on Yamaha XT and SR series (125 to 650cc), known more for its simplicity and extreme reliability than for its performance in terms of speed and acceleration.
    Known as a “beach bike”, like its other ancestor Yamaha Big Wheel, the TW200 suffered big changes along the way but they were made in a single year: 2001. A disk replaced the drum brake in front and they also went to a CV carb, higher alternator output with a 55 watt headlight instead of 40 watt, and a no maintenance cam chain tensioner together with an electric starter. These features can also be found on the 2008 model which means that the bike didn’t suffer any other changes since its rebirth in 2001.
    1994 Yamaha TW200
    2008 Yamaha TW200
    I’ve always wondered if the beach buggy has a 2-wheeler equivalent and now I am convinced it does. Like the beach buggy, Yamaha TW200 has big, wide tires which are meant to gently guide the bike through various kinds of terrains but that isn’t all, is it? Of course it isn’t! The idea of this vehicle is a job well done, fun included, and this reflects on the design: everything is positioned exactly were you would expect to find it. Yamaha TW200 has always been characterized by its aggressive, “I can do anything” look although the engine doesn’t deliver a great amount of power. I wonder what it reminds me of.
    Another thing that catches my eye is the square shape that ended up characterizing this little beast. I’ve noticed that apart from mirrors and wheels, everything on this beauty has edges which give the bike its unique design: aggressive and wide front fender, headlight cover, headlight itself, rear fender and let’s not forget the cube-shaped torque engine that is ready to take you anywhere.
    2003 Yamaha TW200
    I first tested the TW in-town and I have to tell you that it is an admirable motorcycles. The thing I like best about this bike is that the controls are light and small. Shifting doesn’t involve any effort and this means you can ride the bike in city traffic without getting fatigued. After clunking into first, I was off to face the first part of my journey to the dirt. The first gear is extremely short and is testament to the TW off-road intentions with a real surge of power kicking in after engaging second. The tall riding position places you way above the rest of the traffic, offering you a panoramic view of the road ahead. However, despite the TWs high center of gravity and perched seating position, it is suspiciously accurate in lane-changing shenanigans. It might not have the commuting credentials of a scooter, but the TW was comfortably diving into small gaps. This makes the TW a perfect alternative commuting machine, while still being able to tackle the rough stuff along with the open road, to a certai
    n extent. I believe that you’ve already drawn your own conclusion about the bike not being a supermoto.
    The TW won’t help you win the traffic light battle as it has low-down pull but it won’t embarrass you either. The power is enough to make the TW an exciting prospect although it is clear that it lacks top-end punch. The needle jumps up with ease as you race through the gears at low revs but as soon as the speed begins the climb significantly, the TW hits the doldrums and the needle slows considerably until it hits the 60mph roof. The unrestricted space provided by the low, narrow tank and wide seat instills rider-confidence that should make the TW a hit with novice and experts alike. The pace of the TW might not be fast and frenetic, but its smooth delivery is only offset by the very mechanical five-speed transmission which in my opinion is very adequate for this bike although some people need a six-speed transmission but maybe they also need another bike.
    TW200’s low, thick seat, sport/plush suspension and those distinctive fat tires all work together to serve up a smooth ride over all sorts of surfaces. You only need to gas up and go.
    Senior Member iowatdub's Avatar
    Aug 2012
    Iowa
    130
    The big fat tire is so every guy that sees it will say.....wow that is a really cool bike. Are those tires stock? Is that a brand new bike? I always say.....no its been around since the 80's.
    2008 TDUB
    Senior Member nfpgasmask's Avatar
    Nov 2010
    Reno, NV
    500
    Since I first saw the TW200, I wondered the same thing, but additionally, I have wondering why they kept it only a 200cc bike. Why not make a TW350? Is there some reason why more juice would be a bad idea for this bike? I know in Japan they have the TW225, but I cannot imagine the extra 25ccs make that big of difference.
    Bart
    Apr 2012
    374
    Quote Originally Posted by iowatdub View Post
    See how different the reactions can be; my T-Dub always gets looks in the parking lots, always, and lots of people pause and give it a walk-around, but I've had three people be surprised to learn that it's a 2012. Go figure.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Honestly, I think they just read my mind and built it, then every body else wanted one too.
    littletommy likes this.
    Mar 2012
    Boonville, No.-Calif.
    1,357
    Honda had a great trail product line for years, that they dumped. I believe they rightly chased the dollar by concentrating on 4-wheel utility farm & ranch vehicles, and jazzing up their small kids bikes for the american market to look more like a motocross theme. I believe they still offer the trail type bikes in other parts of the world. It's about demand for a product.
    Yamaha has found a niche product in the tw line, and for some reason has decided to keep their hats on straight with it. That seems a good decision, as it probably is a good seller around the world, without having to do any major redesign or re-tooling, and allowing for a simple inexpensive parts supply chain for both building, & maintaining the bike. It also has a good service life, and is replaced often enough by consumers to help maintain sales.
    If another major cycle producer were to try & introduce a competing product for the tw market, it would either fail, or cause sales of both to drop, and cause yamaha to pull the tw line.
    I'm curious about which country buys the most tw's?
    Senior Member tw200sgp's Avatar
    Mar 2012
    Singapore
    258
    There is an Suzuki equivelant around to the TW200 - I've seen them in Singapore. You can mistake them for each other. I'm not sure of the model no.
    Mar 2012
    Singapore
    258
    Ah - it's the Suzuki Van Van. 125CC. http://en.wikipedia.org/wiki/Suzuki_RV_125_VanVan
    Mar 2012
    Singapore
    258
    There is a 200CC Van Van! 6 speed box as well. http://www.bikez.com/motorcycles/suz...n_200_2012.php
  1. MrBracket's TW200 Build
    By mrbracket in forum Performance and Customization
    Last Post: 03-14-2016, 11:43 PM
  2. NiqHowie's 2012 tw200 "supermoto" build
    By niqhowie in forum Performance and Customization
    Last Post: 04-14-2013, 10:38 PM
  3. Rekka, my TW200 custom build
    By marpi in forum Performance and Customization
    Last Post: 01-20-2013, 09:21 AM
  4. I started a blog for my TW200 build.
    By nfpgasmask in forum General Discussion
    Last Post: 10-14-2012, 09:31 AM
  5. TW200 Fat Wheel build
    By bangkokbonk in forum Performance and Customization
    Last Post: 11-25-2011, 03:55 AM
1994 tw200
2001 yamaha tw
2001 yamaha tw200 review
tw200 review
tw200 reviews
tw200 tires
what i dont like about yamaha tw200 review
yamaha tw 200 reviews and reliability
yamaha tw user review
yamaha tw200 off road
yamaha tw200 review
yamaha tw200 reviews
