Picking up my tw200 today
Results 1 to 10 of 17
    Junior Member toddmurdoch's Avatar
    Sep 2012
    Alaska
    12
    Hello from alaska, im just heading over in a few hours to sign the paperwork on my bike and pick her up.
    Any "MUST DO's" for a brand new tw200 (2012)?
    Ive read about the chain, does that apply etc, just looking for info like that.
    Thanks guys.
    Todd
    2012 tw200
    dual sprocket 47/50
    rejetted 130
    Mar 2011
    Gobles, michigan
    1,824
    Just check out oil level-brake levels. Oh heck anything with liquid... If you can trust the dealer then battery level won't be an issue for the rest of the year.
    Tire pressure,chain adjustments etc.
    "NOW" go out there and get use to the way she rides and handles.................... (o;. Have a blast....................................OMM.
    Sep 2012
    Alaska
    12
    I think its gonna be perfect for me. Im coming from a wingy rm125 dirt bike, im to old to be trying to keep her revved up and flying all the time, it definitely wasnt a trail bike.
    Cant wait to get on the tw, seemes like the perfect bike for the part of alaska i live in.
    2012 tw200
    dual sprocket 47/50
    rejetted 130
    Junior Member PerfMoto1's Avatar
    Aug 2012
    Michigan
    26
    Welcome from the lower 48. Hope you enjoy your new Dub.
    Snoop
    Junior Member WY_TW200's Avatar
    Aug 2012
    Wyoming
    8
    Welcome! I have been all smiles since I took delivery of mine.
    Jun 2012
    Southern Michigan
    269
    Make sure the clutch spring is on correctly.
    Enjoy!
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    The stock chain does suck, but there isn't a reason I can think of not to use it until it dies. Only problem with it is that it doesn't last as long as it should.
    -Szj
    2001 TW
    The Southwest
    566
    If your dealer there is anything like my dealer where I bought this bike, don't trust them to do anything right. Check everything that's important to you, like the motor oil and tire pressure. I should have gone over the entire thing before I bought it, but it was late, I was tired and I was eager to get it home. I still need to adjust a turn signal that for some reason, the assembler must have thought existed to signal aircraft.j
    Good luck with your bike! I'm sure you'll it. Welcome to the forum and I'd love to see some AK / TW pictures.
    Senior Member rm_hm's Avatar
    1,619
    The stock chain will wipe out both of your sprockets much quicker then if you put a decent chain on now and get a lot more miles out of them. Once worn you have to replace them all as a set for maximum life.
    Oh and make sure the battery overflow tube is connected to the battery.
    Double check all of your nuts and bolts for tightness.. Much depends weather an old salt or cabin boy got to assemble it out of the crate.
    Junior Member jhow67's Avatar
    Sep 2012
    wisconsin
    18
    waY TO GO I JUST TRADED MY YZ 125 FOR A REAL CLEAN TDUB EVEN TRADE TO A MUCH YOUNGER GUY I ALSO FELT YZ WAS WAY NOT RIDE I WANTED BLUE FUEL KLOTZ AND HAVEN TO HAUL IT EVREY TIME I WANTED TO RIDE. NOW I JUST OPEN THE GARAGE DOOR AND HIT THE MAGIC BUTTON AND AIM N SHOOT. UP IN ALASKA U SHOULD HAVE A BLAST JUST KEEP YOUR EARS OPEN FOR THE FIRST 500 OR SO LISTEN FOR UNUSUAL NOISES NO HEADPHONES N HAVE FUN
  1. First ride after picking the tw200 up
    By beefcake morris in forum General Discussion
    Last Post: 01-21-2013, 07:30 PM
  2. TW200 died in traffic today
    By tw200sgp in forum Technical Help
    Last Post: 04-27-2012, 08:14 AM
  3. picking out new bars
    By phazer in forum Technical Help
    Last Post: 12-17-2011, 05:50 PM
  4. Picking up the pieces
    By disgruntled in forum Technical Help
    Last Post: 05-13-2011, 02:13 PM
  5. Got new to me 08' TW200 home today pics.....
    By majorbanjo in forum General Discussion
    Last Post: 02-13-2011, 08:13 PM
