BACK-UP Parts? What to have Extra? Remote location possible
Results 1 to 10 of 13
Like Tree21Likes
Thread: BACK-UP Parts? What to have Extra? Remote location possible
    Junior Member T-Dub-Luv's Avatar
    Nov 2017
    Crazy
    16
    So I may be shipping my TW overseas, parts "may be" available, at a very high premium shipped to me... or they could be impossible to get. I could be in a wet/sub-tropical, near ocean area. I know I will have access to Fuel and maybe crankcase oil.
    Can you give me a list of what to take with me, prioritized?
    So far I was considering an extra one of each of the below
    - New Carb, or rebuild kit
    - Lithium Battery
    - 0-ring chain
    - Tire inner Tubes
    - Extra headlight bulb
    - Air Filter
    - oil filter
    - spark plug
    What else should be here? And are there a best brands I should be listing next to these parts?
    Thanks ALL for the input
    littletommy and Badgerflorida like this.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Clutch cable.
    Senior Member GCRAD1's Avatar
    Jul 2017
    SoCal
    192
    I have a spare clutch lever mounted to the frame.
    Attachment 152458
    •*Extra Chain link / Chain Breaker
    Hidden Content 2016-TDUB • Built Suspension • LED Headlamp • FMF Powercore4 • Skid Plate • *fifteen/49 sprockets • EVO Air Footpegs • KX High (108mm) bars •1-1/8 Bar Risers • Rally Pro X-Strong Handguards • 714 Soft Touch Rally Grips • 241 Front Tire • Rear Rack • Front Rack
    18,845
    Ride On tire sealant or some method of breaking the bead on rear tire in event of a flat.
    Some way of inflating tire
    SeaFoam
    10 & 12 mm sockets and wrenches
    Spare 10 & 12 mm sockets and wrenches
    5mm Allen wrench cut a bit shorter to readily fit into carb manifolding and valve cover bolts
    Service Manual
    Feeler gauges for valve adjustment
    Spare ignition key
    O-ring chain wax
    Mar 2015
    Ynys Môn
    4,594
    About the only other thing that can stop you is the CDI - given that Tom is now doing them at half price, might as well pack one (doesn't take up a lot of room)
    Bulbs and fuses might be good idea while you at it (a single headlight bulb is unlikely to be enough - you get a short - takes out the bulb - still got the short, takes out the replacement - rinse and repeat) ......
    maddawgj likes this.
    - Hidden Content
    18,845
    How does an incandescent bulb short out, or be damaged by a short circuit anywhere else?
    Peterb likes this.
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    Depending on what year ur bike is, I say kick starter. If it dies in the middle of no where u will be glad you have that. Ride-on both tires, bar protectors, maybe a 12v socket to help charge a phone? in emergency. Maybe get a battery jump pack, can also charge phones. Id go x-ring chain if ur gonna change before you go imo. Maybe make a tool kit/pouch and have plug/small tool/ bulbs/ extra chain master link in it? I wouldnt worry about a clutch lever if you have bar protectors imo, ur chance of breaking would be alot... less. Maybe a 12v small air pump or co2 pump. If you dont already have a rear rack defeniatly THAT!
    2005 TW200
    2007 Sportster 1200
    Mar 2015
    Ynys Môn
    4,594
    Elementary my dear Watson - https://www.thespruce.com/light-bulb...es-why-1152457
    In the case of the TW, a short “could” provide up to 14.5V which is testing to say the least for a bulb rated at 12v — vibration or bad manufacture can be another cause — why take the risk for such an inexpensive light weight item ?
    Given the potential for higher moisture content than usual on this trip — any part of the electrical system can “jump”
    I have a (240v) LED lighting system in my kitchen — bulbs are supposed to last for many years — yet one of them has crapped out in less than three months — you simply cannot rely on anything, especially in the middle no-where …..
    - Hidden Content
    May 2014
    Florida Panhandle
    587
    Maybe a stock metal screen oil filter, as they can be reused/cleaned. While the paper 1's are throw away.
    2005 TW200
    2007 Sportster 1200
    18,845
    Don't understand Purple, on our TWs just what is potentially shorting out to cause this theoretical voltage surge to the headlight bulb? I would like to understand so as to mitigate the risk if possible.
  1. Riding Solo into Remote Areas
    By revtbob in forum Trails, Off-road, and Adventure Riding
    Last Post: 07-07-2017, 10:48 PM
  2. Extra parts
    By Jd87 in forum Technical Help
    Last Post: 12-18-2014, 09:41 AM
  3. Back up her backside! The back way! Now with GoPro time-lapse pics.
    By DonBenito in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-16-2013, 10:23 PM
  4. Many extra parts.....
    By randucci in forum TW200 Classifieds
    Last Post: 07-24-2012, 04:52 PM
news
