Bridgestone Trail Wing 204
Results 1 to 10 of 20
Like Tree30Likes
Thread: Bridgestone Trail Wing 204
    Banned Vishwa Kau's Avatar
    Dec 2015
    Sri Lanka
    83
    What's the diffrence of these two tyres? Specially the one with Blue & Yellow line
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    The 203/204 combo is a good choice if most of your riding is on pavement. They even work on hard pack dirt roads but not very well in mud.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,933
    The tire with the stripes looks brand new. The other one could be a used. Shop around. I got a new Shinko for mine for about $70.00. This will be the first time I used something besides the Bridgestone.
    1993 TW200 just over 46,000 miles
    Dec 2015
    Sri Lanka
    83
    Quote Originally Posted by Ken View Post
    How it goes ? Better Than The Bridgestone Tyre
    Mar 2015
    Ynys Môn
    4,594
    The strip is only there to indicate that the tire has not been used – 20 miles and the stripe disappears ....
    - Hidden Content
    Dec 2015
    Sri Lanka
    83
    Can I Install an inner tube in a tubless tyre? Should I put some sealer in a rear wheel before mount atv tyre (Maxxis Ceros) ?
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    1,933
    I still haven't installed the Shinko yet. Bought in December. I have to mount soon since inspection is coming up in February. I was hoping to slide around and play on the slick one first.
    Mar 2015
    Northville, MI
    779
    Quote Originally Posted by Vishwa Kau View Post
    the wheels will not accept tubeless tires. many of us use sealant in the tubes and I have personally found good success with a product called Ride On, not sure of it's availablity outside the US.
    Tire Sealant | Tire Protection System - Ride-On
    2002 TW200 "The Punisher"
    1998 DR350r
    1996 KDX 200
    Dec 2015
    Sri Lanka
    83
    Quote Originally Posted by Mattwings View Post
    Let me know how to use that sealant ? Do I need to put sealant all over the tubes
    Mar 2015
    Ynys Môn
    4,594
    You remove the valve workings from the valve stem, insert the tube of sealant, and squeeze the contents "into" the inside of the tube — replace the valve workings, inflate to required pressure, and your done
    There are many brands out there, but they all do the same thing
    Centrifugal force will balance the tire, and the compound itself if it escapes the tube in the case of a puncture, will partially seal the leak, preventing sudden deflation
    The advantages of using this stuff is two fold — if everything is good with your tires it balances the wheel — if it does all go pear shaped, you can come to a controlled stop, or even make it home …..
    - Hidden Content
  1. Bridgestone TW203/204 tire set for sale
    By Leisure Time Larry in forum TW200 Classifieds
    Last Post: 06-09-2017, 01:31 PM
  2. tire pressure for Bridgestone tw203/204
    By jim in forum Technical Help
    Last Post: 03-12-2017, 09:24 PM
  3. Bridgestone Trail Wing 203/204 tires near new.
    By 82fb in forum TW200 Classifieds
    Last Post: 03-05-2016, 05:46 PM
  4. BRIDGESTONE TW203-204 TIRE PRESSURES
    By thumper in forum Technical Help
    Last Post: 10-30-2013, 07:53 PM
  5. installing Bridgestone TW203/204's difficult?
    By GlassAnkles in forum Technical Help
    Last Post: 08-28-2013, 07:40 AM
Tags for this Thread
