To slime or not to slime that is the question......
Results 1 to 9 of 9
Like Tree31Likes
  • 3 Post By dman33
  • 6 Post By Gulfrider
  • 7 Post By Chip's T-Dubya
  • 1 Post By Ken
  • 3 Post By Xracer
  • 4 Post By Motoad
  • 5 Post By RockyTFS
  • 2 Post By Fred
Thread: To slime or not to slime that is the question......
    Member dman33's Avatar
    Sep 2017
    SOUTHEAST IDAHO
    49
    I have used slime in some tires and it is such a nasty gooie mess when you change out your tube I opted to NOT use it in the future. i have been reading here that many TW owners are using Ride on tire sealant. how does it compare to slime? its it a messy mess when you get a flat and change your tube eventually or is it only for tubeless? seems like the ticket for an ATV tire on the factory rim that would be impossible to fix out on the trail.
    Thanks
    Dman
    DMAN
    TW200D
    HODAKAS, 950 KTM ADV, YAMAHAS
    "EVERY SOLUTION IS THE SEED OF THE NEXT PROBLEM"
    YOU CAN HAVE IT GOOD, FAST, OR CHEAP = PICK 2
    IF ITS GOOD AND FAST, ITS NOT CHEAP. IF ITS GOOD AND CHEAP ITS NOT FAST, IF ITS FAST AND CHEAP , ITS NOT GOOD.
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    Ride on is the way to go, slime makes a mess and will so to say concrete the tire to the rim. Ride on wont. Plus ride on helps balance the tire
    Ken, JagLite, littletommy and 3 others like this.
    2005 TW200
    2007 Sportster 1200
    Junior Member Chip's T-Dubya's Avatar
    Dec 2017
    Stockton, Ca.
    24
    I just put a new front and rear tire on and used ride on. I removed any wheel weights and took it for a spin, the tires feel good and balanced and I should have a little puncture resistance.
    So far so good,
    Chip.
    Fred, JagLite, ejfranz and 4 others like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,933
    I have used Slime for a long time. Yes, it is messy. It shouldn't weld your tire to the rim unless you had an air leak. I was considering the Berryman's tire sealer which has good reviews. According to what I saw of Ride On it gets the direct center contact patch only. What if you get a nail more on the side of the tire? Read the negatives on Slime. I think half the people don't read the instructions. The tubeless Slime will not rust your rims or corrode aluminium. The Slime for tubes is a little different formula. Shop around, there are a few different sealers out there. I researched this a while back but I didn't save my information. There's one sealer which does the biggest holes and will seal it even on the side. I am sure it is messy. Tractor Supply had one sealer which was real good according to reviews but I think they only went to Slime now. I was considering that one also. Check out Amerseal.
    Smitty Blackstone likes this.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    I've been using Amerseal for some time now. Its not as messy as Slime and in my case slowed the air lose enough that I was able to get the KLR off the road before the tire went flat. I get mine from Napa.
    littletommy, Ken and JagLite like this.
    Senior Member Motoad's Avatar
    Oct 2014
    Creston, BC
    548
    Last time I "used" Slime was at a border crossing when asked to open my side cases and it had broken open inside. On the plus side the border guy cut the search short.
    JagLite, littletommy, Fred and 1 others like this.
    Hailey, ID
    3,377
    Ride On works in tubed tires, it just won't seal as big a hole. Never had a flat in 16,000 miles. It's more expensive, though, and it takes three 8 oz. bottles to do both TW tires.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    18,845
    So RideOn won't cut short a border inspection like Slime ?
    Sent from my XT907 using Tapatalk
    Ken and littletommy like this.
    Lake Placid,Florida
    3,786
    Using Amerseal in North Korea will get you arrested.
  1. Slime
    By JGillespie in forum General Discussion
    Last Post: 10-23-2014, 07:58 PM
  2. Thoughts on Slime for tires?
    By Olydog in forum General Discussion
    Last Post: 08-20-2012, 12:13 PM
  3. Slime air compressor
    By qwerty in forum General Discussion
    Last Post: 07-14-2012, 03:05 AM
  4. Slime ages
    By peruano in forum General Discussion
    Last Post: 06-18-2012, 05:59 PM
  5. Slime Yes or No?
    By cigardog57 in forum Technical Help
    Last Post: 08-15-2011, 08:45 PM
