Hitch Carrier For Lifted Truck
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree59Likes
Thread: Hitch Carrier For Lifted Truck
    Junior Member JB36's Avatar
    Feb 2018
    14
    Hi everybody. I'm looking to get a TW200 (which will be my first motorcycle). I need to be able to haul it home but my truck has a 6 inch lift with 35 inch tires. I don't feel comfortable putting it all the way up in the bed. I was thinking a hitch carrier would be easier. My question is do you think the ramps that usually come with them will be long enough to get the bike on the carrier? Should I make a longer ramp or get a lower adapter that drops the whole carrier a few inches?
    Here's a picture of my truck
    Senior Member UncleRandy's Avatar
    Feb 2015
    Alaska
    165
    Hello JB. I can tell you from my experience with my hitch hauler that the ramps that came with mine are too short-even for my 2000 F350 with stock tires! FWIW-I have the Versa-Hitch hauler. I had a friend fabricate a 6" "drop hitch" for my rig because I use my hitch hauler in a front-mounted receiver too. These are not commercially available (that we could find) so we fabbed one up using existing hitches and welded gussets onto BOTH sides. This is a rudimentary pdf. of what we fabbed and your dimensions will likely vary. We also load tested it with a 550 lb BMW for 1 hour. Total Cost: About $40 for the hitches, pins and paint.Capture.PNG
    Senior Member Joemama's Avatar
    Apr 2012
    Lake County, Ca.
    1,249
    I have gone from a Ford f150 to a Ram 2500, both 4x4. The f150 was easy to use a hitch hauler with no modifications. The 2500 is enough higher that using the hauler with no modifications is very difficult, and unsafe. Rage Powersports does make a drop adapter. I will be making my own. My plan is to use 2.5 box tubing since my hitch is class V. Both tubes will be the same length with 2 3" pieces standing vertical between them. The lower tube will have pin holes that will allow for the hauler to be attached either extended or close to the bumper keeping it the same distance from the bumper when not during the adapter.
    TW-Brian likes this.
    Senior Member Motoad's Avatar
    Oct 2014
    Creston, BC
    548
    I use that drop gizmo with the rack. Works great.20150925_123730 (Medium) (2016_12_04 20_59_33 UTC).jpg
    littletommy likes this.
    18,845
    I gave Admiral one of these I didn't need, does same thing if mounted inverted from photo below: Drill your own pin hole to optimize location.adapt.jpg
    It was surplus from a similar lowering job as I had the drop Z-bend welded directly onto my MotoHitch instead in order to keep TW as close as possible to heal vehicle.
    littletommy, Ken, admiral and 2 others like this.
    Senior Member nihil's Avatar
    Jan 2018
    314
    Quote Originally Posted by Motoad View Post
    That's the same rack that came with my bike, the guy I bought it from bundled them together. I've been a little iffy about using it. Paranoid it's going to fall off the back.
    18,845
    Don't be like this guy:
    Needs three of these to limit play even on the highway much less Jeeping: tighten.jpg
    Feb 2018
    14
    I was actually looking at a similar product and was wondering if it could be turned upside down like how you did it. How many times have you carried the bike that way?
    Nov 2010
    Frostbite Falls Ill
    2,719
    Or you could just ride the bike up a ramp into the bed of the truck and tie it down there. This is the cheapest of all answers to the problem.
    And the most secure.
    smthng and Smitty Blackstone like this.
    Phelonius
    Apr 2014
    985
    If you're an advanced trials rider and can balance on it going down backwards to unload it!
    Smitty Blackstone likes this.
  1. Hitch Carrier vs Truck Ramp.
    By Skunked again in forum General Discussion
    Last Post: 03-01-2016, 01:04 PM
  2. Hitch carrier tray
    By vanillagorilla1 in forum General Discussion
    Last Post: 02-29-2016, 10:00 PM
  3. Hitch mounted carrier
    By Michael Bryce Winnick in forum General Discussion
    Last Post: 11-26-2015, 07:13 PM
  4. TW on a hitch carrier?
    By Nortguy in forum General Discussion
    Last Post: 03-17-2015, 12:54 PM
  5. Rage Hitch Carrier
    By bway in forum General Discussion
    Last Post: 09-16-2013, 08:46 AM
news
