information please
Results 1 to 10 of 18
    Junior Member tazewellteedubb's Avatar
    Sep 2012
    12
    I have my first tw200....its a 2012....i am planning a 3hr ride this tuesday....typical speed will be 55-60....should i stop occasionally to give the motor a break? At this speed it sounds like it is wound pretty tight and is red lining according to the speedometer....like i said...my first bike...so...information would be greatly appreciated!
    Thanks and God Bless!!
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    Quote Originally Posted by tazewellteedubb View Post
    Provided you have completed the break in as the manual suggests the engine shouldn't need a break. I've ridden all day at about 50-55.
    -Szj
    2001 TW
    Sep 2012
    12
    Quote Originally Posted by Sweetzombiejesus View Post
    ok....im sittin on a little better than 800 mile now and have not ridin it hard at all....took the precautions the manual recommended.
    Mar 2011
    Gobles, michigan
    1,824
    U-B-good too go. (o; I still would vary your speed now and then.... Good luck with your butt....... OMM.
    Senior Member iowatdub's Avatar
    Aug 2012
    Iowa
    130
    I think the stock gas tank is designed to give the bike a break. Sure seemed like i filled it alot on my weekend outing about a month ago.
    2008 TDUB
    Sep 2012
    12
    yeh....i did a 60 mile trip about a month ago....not too bad butt noticeable!! LOL...
    Jun 2012
    Southern Michigan
    269
    If you haven't already done so, change your oil and clean the filters to remove break in metal bits.
    Senior Member Woofhound's Avatar
    Federal Way/Cle Elum Wa.
    369
    Ride it like you stole it. The TW will handle 60mph a lot longer then your butt will
    2009 WR250R
    2005 V-Strom
    1993 Shadow 1100 with Ural sidecar
    2008 H-D Ultra Classic
    2009 Zuma 125
    2004 Zuma 50
    2000 WR400F
    Aug 2011
    Cayce, SC
    3,109
    The red line on the speedometer is not the engines redline. It is cautionary from when the speed limits used to be no higher than 55. You'll have a hard time keeping it at redline if you get there at around 78mph stock. Ride on! And do what bullspit said if you haven't already.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Desert, SoCal
    7,369
    Ditto. If it's been broken in per procedure change the oil and let 'r rip.
    A couple of us ran ours at highway speeds continuously for 22 hours recently. They can hang.
  1. Information on crankshaft
    By chasejamy in forum Technical Help
    Last Post: 11-24-2011, 09:07 AM
  2. Carb Tuning Information
    By Larry in forum Performance and Customization
    Last Post: 09-03-2011, 05:05 PM
