Mastodon tire on rear other questions???
Results 1 to 6 of 6
Like Tree7Likes
  • 1 Post By phelonius
  • 3 Post By TW-Brian
  • 1 Post By Fred
  • 2 Post By dman33
Thread: Mastodon tire on rear other questions???
    Member dman33's Avatar
    Sep 2017
    SOUTHEAST IDAHO
    49
    I am putting a mastodon 26x9x14 tire on stock rim on my ride I have read all the how too's so no questions about that subject. I am wondering because it is a taller tire do I need to do something to the front forks to maintain the trail? like put them down in the triple tree as far as they go? I would think it would have some impact on handling.
    Thanks.
    DMAN
    TW200D
    HODAKAS, 950 KTM ADV, YAMAHAS
    "EVERY SOLUTION IS THE SEED OF THE NEXT PROBLEM"
    YOU CAN HAVE IT GOOD, FAST, OR CHEAP = PICK 2
    IF ITS GOOD AND FAST, ITS NOT CHEAP. IF ITS GOOD AND CHEAP ITS NOT FAST, IF ITS FAST AND CHEAP , ITS NOT GOOD.
    Nov 2010
    Frostbite Falls Ill
    2,719
    It will have an effect of raising your final drive ratio too. You may want to go a tooth or two larger on the rear sprocket.
    littletommy likes this.
    Phelonius
    Pleasanton, CA
    5,747
    Hey Dman,
    In theory, you are correct. But in practice, you'll never notice the difference.
    If you are successful in getting that Mastodon mounted (and I certainly hope that you will be!), the handling of your TW will be more like a rototiller than a precisely dialed-in sport bike .
    Don't sweat it.
    18,845
    Yes, I would recommend putting the forks as far down in triple trees as possible. It will not noticeably lessen the mild increase in rake that the Mastodon introduces, but will help maintain the maximum front suspension travel available. You don't want the forks bottoming out by having fender cross brace slam into bottom of lower triple tree. .
    Sep 2017
    SOUTHEAST IDAHO
    49
    I got the sprocket covered I have a 55 with the 14 front so the ratio should be good. I am putting the stiffer springs and the emulators on the front also. it would seem that heat is the key to getting the tractor tread on the stock rim. My plan is to put the semi mounted tire in a "box" like a large shipping crate with a small propane salamander type heater blowing in to get the tire up to a good hot temp then try to seat the bead most of the posts indicated if the tire was warm it seats pretty easy. I will post some pics and a report of how that goes.
    littletommy and Fred like this.
    DMAN
    TW200D
    Member koolhandlinc's Avatar
    Feb 2018
    Tulsa
    89
    I can't wait to see this. Should be pretty neat to see.
  1. TW204 front tire and rear stock tire
    By jgaff in forum Performance and Customization
    Last Post: 06-07-2015, 01:37 PM
  2. Big Tire BW200 Rear Front Tire
    By Beauew in forum Performance and Customization
    Last Post: 05-04-2015, 05:48 PM
  3. FS: CO - Shinko SR244 front tire and Bridgestone TW34 rear tire
    By Nicholast in forum TW200 Classifieds
    Last Post: 12-06-2014, 10:02 PM
  4. Replies: 13
    Last Post: 09-14-2014, 10:36 AM
  5. rear tire change...surface rust...tire lube?
    By blackmouthcur in forum Technical Help
    Last Post: 04-13-2014, 09:53 AM
