Raising the bar!
Results 1 to 8 of 8
Like Tree12Likes
  • 2 Post By dman33
  • 2 Post By littletommy
  • 1 Post By stagewex
  • 4 Post By troll
  • 2 Post By Peterb
  • 1 Post By Mattwings
Thread: Raising the bar!
    Member dman33's Avatar
    Sep 2017
    SOUTHEAST IDAHO
    49
    Raising the bar!
    The handle bar anyway: I want to raise the handle bar 2" any issue with the cables length? is there enough slack for that?
    Thanks
    littletommy and Badgerflorida like this.
    DMAN
    TW200D
    HODAKAS, 950 KTM ADV, YAMAHAS
    "EVERY SOLUTION IS THE SEED OF THE NEXT PROBLEM"
    YOU CAN HAVE IT GOOD, FAST, OR CHEAP = PICK 2
    IF ITS GOOD AND FAST, ITS NOT CHEAP. IF ITS GOOD AND CHEAP ITS NOT FAST, IF ITS FAST AND CHEAP , ITS NOT GOOD.
    Spokane, Washington
    17,422
    Yep..
    1st John 1:9
    John 3:16
    John 3:17
    Jun 2016
    New Rochelle, New York
    1,775
    I went with the 1 inch risers. These are Tusk and I think I bought them from Procycle? Seemed like there was still plenty of slack when I was done with the install. Always want to check that no cables are binding so as throttle doesn't advance when you turn the handlebars. That'll get ya buying some new underwear if you happen to be riding when it happens.
    Truthfully for myself... if I had to go higher than 1.5 inches I would have just gotten bigger (and better) bars with a higher "kick" at the bend.
    Stock
    1 inch riser kit.
    Kit come with a bigger replacement for the OEM bolt. Actually nicer hardware.
    You'd be doubling this below (riser and bolt) so make sure you really want to do that.
    I'm 6'2" with really long arms (like I could be dragging my knuckles). I'm real comfortable with the 1 inch. I also changed the seat and that also has to be taken into consideration.
    Trail Woman likes this.
    Senior Member troll's Avatar
    Nov 2013
    frozen wasteland of the barren north, Yukon Territory, Canada
    1,204
    I used 2" pivoting Rox risers and did loosen the oem wire and cable fixtures.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,484
    Me too. Rox risers rock!
    Elvesus and Fred like this.
    Jun 2016
    1,775
    Yeah, ROX are really nice. Mine are primitive compared. Of course, so am I.
    Mar 2015
    Northville, MI
    779
    2" on mine and it required some minor adjustments, but all stock cables and wiring still worked. That would be about max from what I remember.
    troll likes this.
    2002 TW200 "The Punisher"
    1998 DR350r
    1996 KDX 200
    Jun 2015
    Nova Scotia
    1,406
    Quote Originally Posted by stagewex View Post
    Stock
    1 inch riser kit.
    I got the same ones. It's surprising how much of big difference the little height added is for your comfort and handling.
  1. Raising Forks-Help!
    By U2star in forum Performance and Customization
    Last Post: 03-24-2016, 06:04 PM
  2. Bar end mirrors under the bar
    By Russandkava in forum Performance and Customization
    Last Post: 07-04-2015, 01:09 PM
  3. Hell raising Ride
    By Mel in forum General Discussion
    Last Post: 01-27-2015, 07:06 PM
  4. Raising The Handle Bars
    By RikR in forum Technical Help
    Last Post: 08-21-2013, 05:14 PM
  5. Raising The Handlebars
    By RikR in forum Performance and Customization
    Last Post: 08-17-2013, 08:31 PM
