Lithium grease
Results 1 to 5 of 5
Like Tree4Likes
  • 4 Post By Smitty Blackstone
Thread: Lithium grease
    Senior Member Cascade Rider's Avatar
    Sep 2017
    Kent, Washington
    123
    Lithium grease
    I don’t buy lithium grease often. I see that it now comes in a aerosol spray. Any experience with spray lithium grease as it applies to motorcycles?
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    773
    I personally don't like it on motor vehicles - it stays sticky and catches grit etc.
    Jun 2014
    Bel Air Maryland
    4,169
    Only part I have ever used it on is the kickstand
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Sep 2014
    Mamaroneck, NY
    2,181
    Goes on too thin and runs sometimes making a mess.
    I have a tub on the bench with a small flux brush. Works great.
    Dec 2015
    San Diego
    1,864
    I use on my trailer hitch ball.
  1. Grease Your Chain Fast
    By TopPredator in forum Technical Help
    Last Post: 05-10-2016, 10:47 AM
  2. Grease nipple size?
    By rtf in forum Technical Help
    Last Post: 06-12-2013, 06:55 PM
  3. Needle bearings and Moly grease
    By frog13 in forum Off-Topic
    Last Post: 06-11-2013, 05:53 PM
  4. Brake fluid and lithium grease
    By Dwight in forum Technical Help
    Last Post: 01-21-2013, 08:50 PM
  5. Grease in Magneto (?)
    By msmiller in forum Technical Help
    Last Post: 09-07-2012, 08:13 PM
