Chain Life
Results 1 to 5 of 5
Thread: Chain Life
    Junior Member Kannonball's Avatar
    Jul 2012
    the mountains
    4
    I have a TW 200 I recently bought that now has 3000 miles on it, had about 1000 on it when I got it. I adjusted the chain about 1000 miles ago and noticed rather large difference between the tightest and loosest spots on the chain but now on the second adjustment the difference is HUGE. I think the chain is shot. Since I've ahd the bike the chain has been kept clean and lubed and the bike has only been ridden by my wife - she doesn't ride it very hard at all. 3000 miles seems awful short for chain life, is this normal? Any suggestions on a replacement? I'm thinking that maybe the original chain that Yamaha uses is not the best quality - seems like a light, low horsepower bike with a gentle rider should do better than 3000 miles per chain. What do I need to know to order a chain other than 60 links / 428 pitch? Suggestions on a place to order?
    Thanks,
    Bruce
    Senior Member rm_hm's Avatar
    1,619
    The oem chain is legendary for it's cheapness I was having to tighten mine after every 100 miles.
    What do both sprockets look like? If they are showing a lot of wear you will need to replace everything.
    Jul 2012
    the mountains
    4
    Sprockets look good, one of the first things I did when we bought the bike was to put a 47 tooth sprocket on the rear (got it from Superior Sprocket) Made a big difference, bike is still geared low enough for our use on fire roads and the like but much better for 55 mph on the pavement. The new rear sprocket is aluminum so I'll keep a close watch on it as well as a close watch on chain condition.
    Bruce
    Senior Member peter's Avatar
    Jul 2011
    Providenciales, Turks & Caicos
    398
    There is a lot written on this forum regarding to chains. In a nutshell, the stock chain sucks (but mine lasted for about 8k miles). Most recommend an O-ring chain and the sprockets should be changed at the same time. Search the forum, lots and lots of posts.
    Mar 2011
    Gobles, michigan
    1,824
    With the 47/14 combo go with the 120 link chain.. It's a perfect fit......... I got 5,000 miles from my stock chain........It was toast. I put a higher quality "NON" O ring style.. Now have 10,000 miles on the bike.. The replacement chain is doing great..... OMM.
  1. TW life
    By arrowsmith in forum General Discussion
    Last Post: 12-23-2012, 09:23 PM
  2. Oil Shelf Life
    By Xracer in forum General Discussion
    Last Post: 05-21-2012, 05:58 AM
  3. chain life
    By brent morley in forum General Discussion
    Last Post: 03-14-2012, 12:28 AM
  4. Life in New Mexico
    By peruano in forum Off-Topic
    Last Post: 09-16-2011, 11:53 AM
  5. Look at Life - Scooter Commuter, 1962
    By rm_hm in forum Off-Topic
    Last Post: 01-11-2011, 02:53 PM
tw200 chain life
