did o-ring chain
Results 1 to 6 of 6
    Senior Member howardgene63's Avatar
    Mar 2012
    central missouri
    234
    I have two 2012 tw's, mine has 3000 miles, the wifes has 900 miles. I just purchased two 428v did chains for $92 shipped on ebay, wich seemed like a pretty good deal. I have read on this forum that the sprockets should be changed with the chain. The sprockets don't seem to be worn that badly to me. What would you do? I am sure I could make it till spring on the stock chain, but it does require alot of adjustment.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Quote Originally Posted by howardgene63 View Post
    Change the sprocket with a new chain..............stay with the "old" chain and sprockets until spring....unless of course they are trashed!.
    Senior Member iowatdub's Avatar
    Aug 2012
    Iowa
    130
    I just bought the same chain recently and havent installed it either. I have almost 6000 miles on mine and my sprockets look pretty good. I am tempted to not change my sprockets but while im at it now is the time to do it.
    2008 TDUB
    Senior Member bbagwell's Avatar
    Salem, Oregon
    421
    From what I understand not changing the sprockets will cut your chain life roughtly in half. Sprockets are pretty cheap and not that hard to change. The front one is kind of a pain in the ass because of having to pull the side cover off.
    Bryan Bagwell
    1995 Yamaha TW200
    1983 Toyota PU
    2002 Suzuki Grand Vitara
    Member crjanow's Avatar
    Aug 2012
    Englewood TN
    69
    if the sprockets look good then it will not hurt the new chain. if the sprockets are worn then the life of the new chain will be shortened. this is the case with any chain and sprocket set for anything. as chains stretch the pitch gets longer, as the pitch gets longer the sprockets wear to compensate. if you install a new chain on sprockets with a longer pitch then the chain will much more rapidly wear to fit the sprockets.
    Apr 2011
    Martinsville Indiana
    2,089
    I wouldnt worry about putting new sprockets on the bike with 900 miles but i would at least inspect the front sprocket on the 3,000 mile bike then go from
    There.
  1. New o-ring chain is on
    By goldenhtr in forum Technical Help
    Last Post: 07-31-2012, 07:35 AM
  2. what do you use on your O ring chain
    By aladdin in forum General Discussion
    Last Post: 05-30-2012, 03:48 PM
  3. New O-Ring Chain: Q's
    By bend42 in forum Technical Help
    Last Post: 11-02-2011, 10:14 PM
  4. o-ring chain
    By mrx916123 in forum General Discussion
    Last Post: 07-04-2011, 09:19 PM
  5. Standard vs. O ring vs. X Ring Chain
    By Fishman393 in forum General Discussion
    Last Post: 05-14-2011, 05:46 PM
