No wheeled trailer?
Results 1 to 6 of 6
    Senior Member zardoz's Avatar
    Aug 2012
    Nova Scotia
    187
    I'm not sure if I've asked this question and can't find any info on the site... so I apologize if this has already been covered. I'm curious what opinions might be.
    I drive a KIA Forte5 so my options are kinda limited. I could get a conventional trailer but would like to explore this idea as it looks damned easy to build my own. I'm looking at building something along the lines of what "Cycle Tow" offers as shown here. To help prevent overheating the trans on the bike I would pop the master link out and remove the chain or zip tie it to the swinger.
    This one look's incomplete to me... I think it needs a cross mounted bar near the back bumper to make tie down better... but it is similar to what I had in mind.
    The KIA is actually the wifes car... I sold my right hand drive Japanese mini truck last spring and haven't replaced it with another vehicle yet.
    z
    Full custom 2008 TW200/250 build pics of my bike... I call her TW (short for "Twice Wicked" for her almost doubled HP Hidden Content )
    Newest member of the herd... 1987 Honda CBX250... this bike will become a board tracker this summer
    Bought another bike last fall (2012) ... 1982 Kawasaki KZ305 it's a "mostly done" bobber project I got for practically nothing
    Desert, SoCal
    7,369
    Haulers of that type have a lot of upsides but they've fallen in and out of favor for perhaps as long as there have been motorcycles. They're a good solution for downsizing.
    The primary arguments against are driveline wear and the potential for catastrophe if the bike should bounce into gear. Backing up can be "interesting" if it becomes neccessary.
    I had one in the '80's and want another now.I never gave a rip about the driveline/tire wear issues. This isn't the sort of rig I'd haul cross country in the first place, but the potential for the bike to fall into gear is real. Most people who've used them at least remove the shifter when hauling so that there's no chance of a pothole dropping the bike into gear. Others remove the chain.
    Pleasanton, CA
    5,720
    I also use a zip tie to hold the clutch lever in against the handgrip.
    Desert, SoCal
    7,369
    Another difficulty that you could encounter with your little Kia is that most hitches made for small cars are limited to Class 1 and have 1 1/4" receivers intended for light duty. You may have a little trouble finding a compatible hitch/carrier carrier combo. Most of the carriers are probably designed for a standard receiver.
    Aug 2012
    Nova Scotia
    187
    Yes I thought of that, I figured if I make my own carrier I could match it up to whatever hitch I get mounted on the KIA.
    z
    Member chickenwingsmmm's Avatar
    68
    If you purchased a real trailer you may start using it more than you think for other projects.
  1. What do you think of this for a T-dub trailer?
    Last Post: 09-28-2012, 12:03 PM
  2. Ayers Garage Build on 2 Wheeled Texans
    By Mad Mac in forum General Discussion
    Last Post: 08-03-2012, 11:29 AM
  3. Trailer
    By CaribbeanTW in forum TW200 Classifieds
    Last Post: 07-06-2012, 09:51 AM
  4. Did someone ask about a TRAILER?
    By Batman1USA in forum General Discussion
    Last Post: 05-10-2012, 09:30 AM
  5. Any two-wheeled hand cannon hunters here?
    By lizrdbrth in forum Off-Topic
    Last Post: 09-29-2011, 12:08 PM
