Suspension Too Stiff
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Little General
Thread: Suspension Too Stiff
    Member ebikerman's Avatar
    Jun 2012
    Fitzgerald Georgia 31750
    50
    I sure would like to soften my suspension, especially the front. My mechanic recommended 5 wt fork oil. Would this make enough difference for a not so agressive rider? I have little hope for the rear with it's non adjusting shock. Any suggestions will be appreciated.
    Another related item...somewhere in the rear suspension is a groaning noise when pressing down on the seat. I can't find any fittings on either of the upper or lower rear shock bushings. How do you lube them? I greased one of the two swing arm fittings. The other would not take any grease and the one that did, took very little. Neither side showed any new grease coming from the bushing.I may need to get a tighter fitting grease gun nozzle. That little grease seemed to stop a similar or same noise for a few miles. Need help here...Thanks !!!
    Hailey, ID
    3,329
    Quote Originally Posted by Dan P View Post
    I"m not qualified to answer the 5 wt in the forks question, but as far as the grease fittings go, they are often neglected. Clean them both with kerosene or other solvent, take a piece of wire or tiny drill bit with a flat end and try to push the ball down into the fitting just a little to break it loose. Then grease until some comes out each bushing. If your nozzle is too loose it will just come out around the zerk fitting, but some fiddling with the angle may allow it to work. Worst case, if they are frozen, replace them....not very expensive.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Jun 2012
    50
    Thanks for the help. Probably need to replace the fittings. The bike is an '06 with only 600+ miles. I just got it a few days ago. Thanks again.
    Jun 2011
    Dothan, AL
    1,715
    If this isn't a type o, then a 2006 with 600 miles is brand new. I say ride the hell out of it and see if it softens up. I wish mine wouldn't bottom out, wanna trade?
    2005 TW200 (SOLD)
    2013 DR650
    Senior Member dganey's Avatar
    Oct 2010
    SE Michigan
    342
    Keep riding. It will soften up. One other option is to remove the top cap and cut the preload spacer shorter--ride a little longer though first. You can use pvc to dial it in then cut the oem spacers to the desired length. Another option is progressive rate springs made for the TW. I have them. Most people on the forum want the front suspension stiffer though. As for the fittings, I had to use two hands to hold the nozzel and have another person pump the grease. It may take a few tries to get the right angle.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Lizardbrth is likely the one to talk to. There is some information he posted here, but I am not sure where. Here is a link. It is also copied to the Wiki TW site. Gerry
    http://tw200.wiki-si...ront_Suspension
    Take care my Friend.........
    Jun 2012
    50
    Quote Originally Posted by dustyg View Post
    Great idea resizing the pre load spacer. I had a professional motorcycle mechanic change the fork oil to 5wt, but no significant difference.....maybe a little. Maybe more in summer. He also softened the rear shock. Even Yamaha did not claim it is adjustable, but it is. There are 3 groves that a circlip like device will fit in. Mine was in the middle position. The softer position grove can be seen with the shock on the bike, but with great difficulty. Shock must be removed to change adjustment. Made some difference maybe??? I agree that the shocks are stiff from being new. One problem seems to be that the front tire is out of balance. Bounces at around 30 mph, but smooths out as you go faster. Don't notice that on dirt roads even hard pacted. Thanks all for your input....Dan P
    Senior Member Little General's Avatar
    Jul 2013
    Mt Pleasant, NC
    188
    I bought an 07 and the tires looked new , but when I replaced them it made a huge difference. Install new grease fittings for sure and check the level of the oil in the shocks. Too much will make it too firm
    lizrdbrth likes this.
    Aug 2011
    Cayce, SC
    3,109
    Suspension too soft?!?! Well I guess theres a first for everything....
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Too soft unless you're 100 lbs.... I just upgraded the front an rear springs to .60 and 15k from Procycle, the difference is amazing, no more bottoming out and more sure footed on the street and more importantly on the dirt.
  1. Improving front suspension?
    By Pengineer in forum Technical Help
    Last Post: 09-04-2013, 07:31 PM
  2. Old, stiff short carburetor boot....
    By zoomer in forum Technical Help
    Last Post: 06-12-2013, 05:04 PM
  3. Suspension Limits new to the forum
    By kev187 in forum General Discussion
    Last Post: 07-25-2012, 01:22 PM
  4. Progressive suspension
    By Pleco in forum Performance and Customization
    Last Post: 02-25-2012, 08:38 AM
  5. Suspension
    By tophat in forum General Discussion
    Last Post: 02-04-2012, 10:36 AM
grease fittings on tw200
how do you soften the suspension on the yamaha tw200
lube stiff suspension bushings
stiff yamaha front shocks
tw200 5wt
tw200 grease fitting
tw200 lube for rear suspension
tw200 soft suspension
yamaha tw200 stiff suspension
yamaho suspension too stiff
zerk grease fitting size
