TW200 Hitch Carrier Help
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree15Likes
Thread: TW200 Hitch Carrier Help
    Junior Member Kifo4173's Avatar
    Apr 2018
    8
    Hi All,
    I've reviewed all the threads I could find on the forum about hitch carriers and our TW's. I still have a few remaining questions..
    The carrier will only be used on my Ram Promaster camper van. I'm hoping to have quick(ish) access to the back doors of the van. My garage there houses a variety of gear, and an outdoor shower.
    Between the Ultimate MX Hauler and a standard hitch carrier, which is quicker to pull a bike on and off?
    My idea right now is to go with the Ultimate MX. It looks like I can let the hydraulic jack down, and this would locate the bike far enough away from the rear doors to open them and have some access? Additionally, a low profile rack is important to me. I don't need something super overbuilt or for a 700lb street bike-this is the only bike I'll ever have on the rack. The Ultimate MX seems like it is the most minimalist. Any comments on this?
    HOWEVER-some of you say that the Ultimate MX isn't ideal with the TW200. Sounds like I at least need the Ricochet skid plate and wider pegs?
    There's a pretty cool swing away hitch accessory made by a small company called Rak Attach. I'm tempted to use this with either the Ultimate MX OR a standard moto hitch carrier. Anyone see a reason to use the Ultimate MX over a standard moto hitch carrier with the swing out?
    Last-if anyone has pictures or general additional comments about low profile hitch racks, especially the Ultimate MX, it would be much appreciated. It appears many of the photos from old threads are broken.
    Thanks!
    jtomelliott49 likes this.
    Feb 2013
    Missoula, MT
    908
    I use the Ultimate MX. It is expensive, somewhat heavy (but, aren't they all). and it takes a bit of experience to use it correctly. However, it DOES work okay with a stock TW. A Ricochet shield and bigger pegs help but are not necessary. I have carried my TW both ways. Plus, it looks cool. It takes about 5 minutes to put the bike on and less than 2 to take it off.
    Having said all that, I do not think I would buy another one. I did get mine for $300.00 on Craigslist. New they are $430.00.
    I am looking for some pictures. Here is a link to a YouTube:
    jtomelliott49 and Fred like this.
    Pleasanton, CA
    5,747
    I have owned both the Ultimate MX Hauler rack and a number of Moto Jack Racks, which are no longer available. Both of these racks are similar in function, but I much prefer the Moto Jack Rack and still own two of them. These types of racks are great if you only have one bike to transport and have a suitable vehicle to use it with.
    Here are some pics of the Moto Jack Rack on my 4Runner. I will try to find some pics of the my TW on the Ultimate MX Hauler.
    Fred likes this.
    Feb 2013
    Missoula, MT
    908
    Attachment 172794
    One more thing. On my 2006 Ford F150, the "platform" sat very high. TW's are lower than most dirt bikes. The TW needed to either be lifted to get it on OR I had to backup to a slight slope to take up some of the height. The DR350 when right on. It's taller. The height is lower my new Ford Edge, so no lifting.
    If you look closely at the photo you will notice the platform rides a a rather tiled angle. This is normal. It still bothers me a bit, however.
    Fred likes this.
    Junior Member Kermit's Avatar
    Apr 2018
    22
    I have the Ultimate MX hauler. It’s slightly too high on my tacoma so I have to lift and wiggle it a bit to get the bike on. I have the stock skid plate and pegs and works fine. It’s pretty quick to load and unload. Rack takes up little space for storage when off the truck. I’m happy with it but never tried the long tray model for comparison.
    Edit. Just saw the link to the rack attach. Sounds like a good idea if it can really support 300 lbs. plus the weight of another rack.
    Junior Member Jdog's Avatar
    Jan 2017
    1
    I have a motorcycle hitch carrier and love it. I use a Toyota Tacoma to carry my TW all over the place, just need to install some 50 dollar helper springs to keep back end from sagging. In my opinion they are the the way to go for the solo rider.
    Only advice I have is to buy one made of steel, not aluminum. I repeat aluminum sucks for this application. There is to much rolling and flexing and aluminum will ultimately crack and fail. Steel although heavier is just better for this purpose as it allows some flex as the bike rocks back and forth on the hitch, which it will do no matter how much you stabilize it.
    Expect to spend around $400 for a well built hitch carrier new. But a good steel one will last forever and are strong enough to throw a street bike on them if needed.
    Jul 2012
    Wet-ern Washington
    1,410
    What Class is your receiver hitch on your van? They are not all the same. I usually always recommend a trailer as the very best way to haul a TW or other motorcycles. However, if that's not an option for you, it's out. A TW is a heavy bike though at 280 lbs. wet, stock, and you have to consider that weight, plus the weight of the carrier, and what stresses on the hitch system that weight will produce while bouncing down the road. A hitch will have a Class Rating or a Weight Rating sticker on it telling the maximum tow rating and a maximum tongue weight rating. The tongue rating is factored as being downward vertical weight at the ball or hook position. A moto hitch carrier will often have the weight out further than the ball would be so having it stick out doesn't just produce vertical force but also a lever type force too. Think about it, check your weight ratings, and make sure you give yourself a good safety reserve. That's my 2 cents. Good luck. I hope that you find a good solution.
    devildog3521 likes this.
    - Leisure Time Larry -
    Member BuddyMack's Avatar
    Jul 2016
    Huntsville, Alabama, USA
    68
    Consider mounting the hitch on the front of the van.
    Sent from my LG-TP260 using Tapatalk
    imlost likes this.
    Now Hidden Content on my 2nd TW - 2002 TW200 33k miles - 130 main 34 pilot - 244 Golden Boy Front - 34 BS rear - ATV Bar - New Rally Perches, Master Cylinder, and levers. This one may take a bit to whip into shape but we'll get there!
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    Quote Originally Posted by BuddyMack View Post
    I have one on the front of my GM pick up and my TW rides up front sometimes.
    Apr 2018
    8
    Thanks all for the replies. Very helpful.
    Is the ultimate MX or the motojack going to be my best solution for carrying the bike as close as possible to the vehicle? If not, is there a particular hitch carrier that holds the bike closer to the rear of the vehicle? I think I read somewhere that one of the benefits of the ultimate MX is that it holds the bike close to the vehicle, but I just want to verify with the TW.
  1. Hitch carrier tray
    By vanillagorilla1 in forum General Discussion
    Last Post: 02-29-2016, 10:00 PM
  2. TW on a hitch carrier?
    By Nortguy in forum General Discussion
    Last Post: 03-17-2015, 12:54 PM
  3. Custom Built Trailer Hitch Carrier for a TW200
    By Fursniper in forum General Discussion
    Last Post: 09-17-2014, 10:39 PM
  4. Rage Hitch Carrier
    By bway in forum General Discussion
    Last Post: 09-16-2013, 08:46 AM
  5. I Bought A Hitch Carrier!
    By Kev250R in forum General Discussion
    Last Post: 05-05-2011, 05:48 PM
tw200 hitch carrier
