Changes by year to the USA TW200 - Page 3
Results 21 to 30 of 40
Like Tree94Likes
Thread: Changes by year to the USA TW200
  1. #21
    Apr 2012
    Out West
    3,059
    base gasket problem actually started with the 2003 years IMO and 2001 is the year for the disc etc change
    Ordering the 2010 gasket was the original fix before clever folks tried the re torque and making sure the threads are clean with a tap
    Badgerflorida and Purple like this.
    "It's Like Warm Apple Pie"
  2. #22
    Feb 2013
    Missoula, MT
    908
    Wasn't entirely sure about the year the fork drain bolts went - i'll probably move it to '96 - although my '98 has them (Japanese import, different beast)
    Can anyone else confirm or deny this ?
    My '95 (it says 3/95 on head tube decal) has fork drain bolts.
  3. #23
    Senior Member white mule's Avatar
    Jan 2014
    NorthWet Oregon
    174
    Comparing my 99 and 94. The 99 on the right side of the frame just behind the steering stem there is a wire loop to retain the wire harness. On the 94 it is a straight wire to do the same job.
    Purple likes this.
    Me and my white mule
  5. #24
    Mar 2015
    Ynys Môn
    4,594
    Quote Originally Posted by goldenhtr View Post
    Couple changes.
    Done - (thanks to everyone) - keep 'em coming ....
    JerseyJeeper likes this.
    - Hidden Content
  6. #25
    Mar 2015
    Ynys Môn
    4,594
    Anyone got an update on the fuse situation ? - pre 2001 it was just the one - not sure of what happened after that ....
    - Hidden Content
  7. #26
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,484
    Comparing my 99 to my 15 other than the changes already listed my 99 has 3.5mm spokes, 15 has 4.0mm spokes, the 15 has hex head bolts on the clutch and stator covers instead of JIS screws (easy upgrade). An earlier post mentions the old W32 rear tire which I also preferred to the W34. It was slightly wider and shorter than the W34 and in my opinion a much better tire in sand.
    Edit: On my 15 it is only the front wheel that has 4mm spokes. The rear remains at 3.5mm. Another little note is that the 3.5mm spoke nipples require a 5.6 wrench and the 4mm spoke nipples require a 6.0mm wrench.
    Purple likes this.
  8. #27
    Apr 2013
    385
    electric changes at disc model, start relay different includes fuse, only uses the white relay, (much better system)
    head bearing were loose on early models??
    thick starter wire goes up and over the top of the engine into the side case on 01 models, goes under left side case on pre 01
    Purple likes this.
  9. #28
    Jun 2015
    Nova Scotia
    1,406
    Quote Originally Posted by vanillagorilla1 View Post
    somewhere early on the rear tire changed. too bad cause I liked the old style one much better.
    Yeah it looks like it would be better off road then the current one. Too bad they're not available anymore
  10. #29
    Junior Member Stasch's Avatar
    Aug 2014
    3
    I have an '87 with a kickstart lever. Most other years don't seem to have one. Wasn't that only for the first year or two?
  11. #30
    Mar 2015
    Ynys Môn
    4,594
    They included a kick start from '87 through to 2000 - post 2000 (2001) came with electric only
    Ironically, the Japanese market bikes and the European all come with the kicker regardless of year - just another example of how hard done by you Americans are I guess
    Welcome to the board .....
    - Hidden Content
  1. 1987 Model Year - First Year for TW200's - Good, Bad, Ugly?
    By TW-Brian in forum General Discussion
    Last Post: 01-07-2019, 01:52 PM
  2. TW200 carburator needed
    By Boike in forum TW200 Classifieds
    Last Post: 04-28-2018, 04:48 AM
  3. 2013 TW200 Parts Needed
    By PWM in forum TW200 Classifieds
    Last Post: 08-05-2015, 09:47 AM
  4. getting a TW200 - chain help needed
    By Yan in forum Technical Help
    Last Post: 09-01-2013, 10:29 AM
  5. Needed: '97 TW200 Stator
    By jbertram32 in forum TW200 Classifieds
    Last Post: 08-08-2010, 10:06 PM
tw200
tw200 changes
tw200 year changes
yamaha tw200 year changes
