Changes by year to the USA TW200
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Like Tree93Likes
Thread: Changes by year to the USA TW200
    Mar 2015
    Ynys Môn
    4,586
    Trying to think of various changes by year to the USA TW200 – so feel free to chime in on this …..
    1987: One off electrical system, some of it AC, such as the head light. Reports of CDI failure. “Unsubstantiated” reports that this year was the fastest, but the ’87 did have a slightly tweaked CDI advance curve.
    1988: Revised electrical system, mostly DC.
    1987 to 1991 and 1992 to 2000 front brake shoes different sizes - choose replacements with care (see post #33 on this thread)
    1996: Front fork drain screws discontinued.
    2001: Changed to disc brake model. Rear foot peg off set changed. Charging system upgraded from 35W to 55W. CV carb introduced, with throttle cables coming in from the other side. Inlet manifold dimensions changed slightly to accommodate CV carb. Kick starter assembly no longer included (but can be added later). Trip meter added, Some electical connectors changed. Handlebar controls updated. Introduced automatic cam chain adjuster. Exhaust mounting changed (see post #17)
    2002: Smaller diameter fuel cap.
    2006: Multiple (increased) reports of leaking base cylinder gasket - see post #21 (Solution is to re-torque, or order later gasket which was stronger).
    2009: Base gasket problem resolved at factory.
    2017: Rear shock unit changed (no improvement).
    See post #26 regarding spoke diameters - " '99 has 3.5mm spokes, '15 has 4.0mm spokes"
    Throughout the years the CDI part number keeps changing, but how relevant this is has yet to be determined, though it’s likely to be a connector type issue rather than a performance issue. Details of CDI part numbers by year can be found here - https://tw200forum.com/forum/technic...nits-year.html
    Any corrections or additions welcomed – this is a joint “hive mind” effort. Once it settles down we can “sticky” it.
    Of particular interest, is the stator assembly, and the crankcase housing it – any info on that issue appreciated.
    I’ll edit this first post as we go along …..
    - Hidden Content
    Spokane, Washington
    17,368
    Dyno results DID prove the mighty 87 WAS just a little faster...
    Purple, Elvesus, Ken and 2 others like this.
    1st John 1:9
    John 3:16
    John 3:17
    Feb 2018
    Western Pa.
    310
    Actually the rear shock was changed in 2017. Does anyone know what the difference is other than the part number?
    Ken, Badgerflorida and Purple like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,927
    Good data. My 1993 had the leaky base gasket also.
    Senior Member Nicoradv's Avatar
    Mar 2018
    North East Texas
    167
    2001 9k miles base gasket leaking.
    2018 According to Happy Trails the muffler mounting has been changed to put it further in side the frame. Need to check tail light location mounts compared to older models. Seems like they way moved also.
    This according to HT when I went to mount HT tail and side racks to a 2001. Going by the way the bolt holes were off I can sorta believe it.
    Badgerflorida, Ken, Purple and 1 others like this.
    If a bike is plated, it's suppose to be ridden, not hauled on a trailer.
    2002 DR650SE, 2001 TW200
    Mar 2015
    Ynys Môn
    4,586
    Good info - keep it coming ......
    Badgerflorida and Ken like this.
    - Hidden Content
    Mar 2015
    Ynys Môn
    4,586
    Quote Originally Posted by sibyrnes View Post
    The adjuster was moved to the outside - https://tw200forum.com/forum/performa...prung-not.html
    On the original, you had to compress and remove the spring to get at it - now you have to compress and remove the spring (but getting at it is easier) ....
    Badgerflorida, Ken and Old n dirty like this.
    - Hidden Content
    Senior Member vanillagorilla1's Avatar
    Nov 2013
    yakima wa.
    797
    2001+. trip meter added, electical connectors changes throughout the bike along with the other electrical changes. handlebar controls updated, throttle cables changes along with the carb and throttle tube. automatic cam chain adjuster.
    somewhere early on the rear tire changed. too bad cause I liked the old style one much better.
    Badgerflorida, Ken, Purple and 3 others like this.
    93 tw. running like clockwork
    225 6 speed complete!
    82 honda gl500 silver wing. sold to a new home 11-24-17
    03 ducati monster 800sie. full rebuild and a danger to the public Hidden Content for sale
    Mar 2015
    Ynys Môn
    4,586
    Yeah - not sure when they changed the TW32 for the TW34
    First post updated ......
    - Hidden Content
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,718
    The secret to the fast 87 is out. It was one tooth higher geared. a 49 as opposed to the 50. Not much, just a slight edge, who would have known.
    Purple, Badgerflorida, Ken and 2 others like this.
  1. 1987 Model Year - First Year for TW200's - Good, Bad, Ugly?
    By TW-Brian in forum General Discussion
    Last Post: 01-07-2019, 01:52 PM
  2. TW200 carburator needed
    By Boike in forum TW200 Classifieds
    Last Post: 04-28-2018, 04:48 AM
  3. 2013 TW200 Parts Needed
    By PWM in forum TW200 Classifieds
    Last Post: 08-05-2015, 09:47 AM
  4. getting a TW200 - chain help needed
    By Yan in forum Technical Help
    Last Post: 09-01-2013, 10:29 AM
  5. Needed: '97 TW200 Stator
    By jbertram32 in forum TW200 Classifieds
    Last Post: 08-08-2010, 10:06 PM
tw200
tw200 changes
tw200 year changes
yamaha tw200 year changes
