tire pressure help
Results 1 to 10 of 12
Like Tree17Likes
Thread: tire pressure help
    Member werwolf's Avatar
    Apr 2018
    Helderbergs Region, Upstate NY
    40
    tire pressure help
    [I]wha[s is the best all round tire pressure for stock tires, dealer said the high end of the sticker.
    I know lower is better in the woods & higher on pavement, any suggestions ? , I have no experience with the TW./I]
    [B][I]LIVE FREE OR DIE - BE SELSELFSUFFICIANT - PRAY OFTEN
    2018 TW -LOADED FOR THE WOODS
    Mar 2015
    Ynys Môn
    4,594
    Manual says 18 or 19 psi for a 180 lb rider - adjust as required
    Lower is better for trail work - 12 to 15 psi
    Higher is better for road and speed record attempts - 22 to 25 psi ......
    werwolf, Elvesus and Rickhem like this.
    - Hidden Content
    May 2013
    Groton, NY
    2,663
    For my riding, which varies from commuting to some nasty, muddy trails, and everything in between, I do 10 psi rear, 14 psi front. Stock rear tire, Shinko 244 front. I've done lower in the rear, really enhances off road traction but risks a rim dent or tube pinch, and handles crappy on the road.
    werwolf likes this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    I run 12.5 in the rear stock tire and 21 in the front Shinko 241. I'm 250# currently with extra gas and tools etc on board and run all conditions from sand, mud and 60mph + a tad on asphalt very often as well as hard cornering on the road. I have run lower pressure in the front, slight improvement off road but takes away from the on road ride to get off road. For me 12.5/21 is A-OK but you may want to knock that down a bit, just depends how hard you push it on road.
    werwolf likes this.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
    Apr 2018
    40
    GUESS I'LL HAVE TO EXPERIMENT, & CHANGE TO CONDITIONS.
    LETTING AIR OUT IS EASY, BUT I DON'T WANT TO CARRY A PUMP!!! (Ha)
    Senior Member Allanb's Avatar
    Mar 2017
    n.w.washington
    260
    10-12 in front shinko 241. Mostly rocky, gravelly two track, but some 65 mph on road. !0-12 in stock rear. Don't notice difference with higher psi on road, but do in sand and gravel
    werwolf likes this.
    Hailey, ID
    3,377
    One way to tackle this is to get a tire gauge, set the pressure at say 16 lbs. for the front tire, take a nail and push in the valve stem and count: one thousand 1, one thousand 2, then recheck. The front tire will lose about 2 psi per second. The rear will lose about 1 psi per second. After a few practice runs, you can get a fair estimate of how many seconds it takes to reduce from 18 to 14, 14 to 12, etc. When you get back to pavement, just give them 5 seconds at the service station and you will be in the ballpark.
    I am comfortable riding home on pavement at 12 front 14 rear, but I understand that gas mileage suffers, so if I can find a station, I will pump them up. Generally, I found that 12/14 reduced mileage to 55 or so, and 18 to 20 got it back up to around 70 mpg.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member Elvesus's Avatar
    Jun 2015
    Nanaimo BC
    311
    I run 18 front and rear for road riding (Shinko 241 in front) and drop to 12 each for longer off-road rides. I carry a compact bicycle pump to air up when I'm back on pavement and have a longer run to get back home. It's a minor hassle pumping them up but not too big a deal (only ~5 min).
    werwolf and admiral like this.
    John in Nanaimo
    2013 TW200 - with Shinko 241 front tire, Rox 2" anti-vibe risers, Polisport Touquet handguards, homemade wind deflector, Manracks utility rack
    Apr 2018
    40
    Quote Originally Posted by Allanb View Post
    [IThanks, say ]what kind of sprocket gearing do you have?[/I]
    Elvesus likes this.
    Apr 2018
    40
    Quote Originally Posted by Elvesus View Post
    small pump may way to go, wont take too much room or weight.
    Thanks
    admiral and Elvesus like this.
  1. Tire pressure?
    By NavyDOc in forum Technical Help
    Last Post: 09-23-2014, 04:21 PM
  2. Tire pressure
    By archery22 in forum General Discussion
    Last Post: 06-13-2014, 10:36 PM
  3. Tire pressure
    By Drifter in forum Technical Help
    Last Post: 10-10-2012, 05:52 PM
  4. tire pressure
    By ridgeline in forum General Discussion
    Last Post: 09-18-2012, 07:27 PM
  5. TIRE PRESSURE
    By Turtle Chaser in forum General Discussion
    Last Post: 09-24-2010, 07:08 PM
