Running without headlight
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Like Tree20Likes
Thread: Running without headlight
    Senior Member Tjmay's Avatar
    Jan 2018
    Destin Florida
    234
    There was a recent reference to this but it didn't really answer the question.
    I ride mostly offroad and only during the day.
    So, I disconnected the connection to the low beam knowing that if I needed the headlight, I could simply switch on the highbeam.
    Will constantly running without the load the headlight places on the system cause any harm to the battery?
    Mar 2015
    Ynys Môn
    4,594
    No - that's what your regulator/rectifier is for ......
    PlacerLode and JerseyJeeper like this.
    - Hidden Content
    Hailey, ID
    3,377
    Not at all, I've been doing that for years. Now you can ride as slowly as you want with no worries your battery isn't being charged sufficiently. You can even disconnect the blue wires to the front turn signals always on feature for even more savings on juice. (At least they are blue after 2001.)
    PlacerLode likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    18,845
    Our experiences indicate that running without the Lo Beam should be OK.
    However there has been theoretical discussions on the forum warning of overloading the voltage regulator/rectifier with a sustained 80 plus watt load at higher RPMs. I do not know the rating of our TW's voltage regulators, nor if there is a variation in rating over the years as stator output has changed since 1987.
    One of my bikes has a low beam cut-out switch. I will utilize it at times at the very least to lessen draw on the battery when engaging the starter motor in cold weather.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,395
    i have also installed a low beam turn off switch and a volt meter on my bikes. it is surprising how high the voltage is when running with no headlight
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Apr 2012
    Out West
    3,058
    my headlights are always unplugged I usually unplug the high beam
    "It's Like Warm Apple Pie"
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by grewen View Post
    Should be 13.8 to 14.8.
    Past 15.0 may have a toil on incandescent elements and electronics
    Fred likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Oct 2014
    Armstrong BC
    2,395
    Quote Originally Posted by PlacerLode View Post
    why do you unplug the high beam?
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Oct 2014
    Armstrong BC
    2,395
    Quote Originally Posted by SportsterDoc View Post
    it'll raise hell on the battery
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Mar 2015
    Ynys Môn
    4,594
    Because engaging the high beam control then turns the head light off
    In the UK, we have a long history of being able to turn the head lights off – low beam or high beam – we have “off”- “low” – “high” – never blew one up yet ……
    Fred likes this.
    - Hidden Content
  1. round headlight / dual headlight
    By fredzaha in forum Performance and Customization
    Last Post: 05-04-2015, 01:32 AM
  2. got my tw running
    By dantilghman1 in forum Technical Help
    Last Post: 01-17-2013, 07:04 AM
  3. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 10:52 PM
  4. Getting my TW running
    By caseyb in forum Technical Help
    Last Post: 04-29-2012, 04:44 PM
  5. need help getting "new" 89 running
    By bpiersall67 in forum Technical Help
    Last Post: 03-14-2012, 04:38 PM
