I've Got Some Work To Do!
Results 1 to 3 of 3
Like Tree9Likes
  • 5 Post By scotti158
  • 2 Post By Xracer
  • 2 Post By scotti158
Thread: I've Got Some Work To Do!
    May 2013
    Groton, NY
    2,663
    Parts came in, just need to wait for the grass to quit growing long enough to get them in. Assumed responsibility for the daughter's lawn with her hubby in the Navy. Really "cutting" into my motorcycle time.
    Fred, Lyterx, Xracer and 2 others like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    You bought oem brake shoes. Good choice!! Now you can grease the pivots and sand the drum.........If you can find the time!
    scotti158 and Ken like this.
    May 2013
    Groton, NY
    2,663
    It rained today so no mowing! First I replaced the rear brake shoes and yup, pulled the pivot, cleaned it up, greased, sanded the rust out of the drum, reassembled with new shoes. The pics below shoe the before and after of the arm position. Also got the new clutch and HD springs in. The Vesrah springs were noticeably longer than the stockers. Hardest part was getting the gasket off the cover. Took a little time and some Permatex gasket remover. I also used some Loctite 243 on the spring bolts, just to be safe. The cover had lots of little gasket pieces from removal so I'm taking the cover to work tomorrow to flush it out good in the parts washer. Reassemble, new filter and oil, and it should be good to go for awhile. The clutch lever had about an inch of free play after reassembly, those friction pads were definitely worn. I'm a little rough on these li'l bikes!
    Ken and Xracer like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
  1. Work After Work
    By Lomax in forum Off-Topic
    Last Post: 01-27-2017, 03:16 PM
  2. Replies: 13
    Last Post: 07-08-2016, 11:15 AM
  3. Had to take a day off work to go to work....
    By Flathats in forum Off-Topic
    Last Post: 06-08-2016, 05:54 AM
  4. Maybe these will work better for me than the Ceros did
    By bananachunks in forum Performance and Customization
    Last Post: 04-01-2016, 11:17 PM
  5. TW at work
    By arbolmano in forum General Discussion
    Last Post: 08-01-2013, 10:29 PM
