New Battery Help
Results 1 to 6 of 6
    Senior Member cptrout's Avatar
    S. Torrance (So. Cal.)
    353
    I think it's time to replace my battery and was going to go to an AGM style battery.
    It this what I need?
    Thanks, I really appreciate the help.
    Germany, Werdau
    1,014
    Hi,
    yes, this one will fit. I use the same type of battery.
    But you will need 2 small foam spacers, because this battery is a bit smaller as the original battery.
    The TW125 type 2 does have the same battery type. And Yamaha uses also here some foam spacers.
    Sebastian
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Quote Originally Posted by cptrout View Post
    Both Spudrider and I have personal experience with Scorpion batteries.
    Read this and decide for yourself:
    https://tw200forum.com/index.php?/top...post__p__12315
    https://tw200forum.com/index.php?/top...post__p__43448
    jb
    353
    Thanks guys.
    It wasn't so much the brand of battery I was asking about as much as it was model number and battery type. I notice on link #1 from jbfla's post that the Motocross battery has terminals that are threaded like the original battery on my 2008 where as the Scorpion battery does not.
    How do my bikes cables secure to the battery terminals on the Scorpion model?
    FL. GA, NC
    2,396
    With a bolt and nut. Often the nut is a rectangular plate that has a threaded hole in the center.
    Jb
    353
    Got it! Thanks again
  1. Battery
    By mga60tw in forum Technical Help
    Last Post: 07-24-2016, 03:57 PM
  2. New battery
    By trbixler in forum TW200 Classifieds
    Last Post: 03-25-2012, 09:24 AM
  3. Best battery?
    By Matthew Rowland in forum Performance and Customization
    Last Post: 02-06-2012, 10:02 AM
  4. How do I get to the battery
    By mike m in forum Technical Help
    Last Post: 02-14-2011, 09:27 PM
  5. Run w/o battery OK?
    By Rohnsman in forum Technical Help
    Last Post: 01-30-2011, 01:32 PM
