down side of tube tires!
Results 1 to 9 of 9
Like Tree11Likes
  • 3 Post By Leisure Time Larry
  • 1 Post By koolhandlinc
  • 1 Post By Gulfrider
  • 2 Post By RockyTFS
  • 2 Post By Fred
Thread: down side of tube tires!
    Member koolhandlinc's Avatar
    Feb 2018
    Tulsa
    89
    I purchased this TW for fun and also as a back up transportation.
    So I start working on my trucks front brakes. Mine has the disk and the hub as an assembly and so I had to run and get the grease cap due to a pin hole. I got almost to the parts store and the back tire is flat. screw in the tire. No tools with me. nothing. took 2 1/2 hours to finally get it home and back to work. I had a bright idea to use a can of fix a flat. It was good for a solid mile. I suspect when I finally get a chance to fix this the tube will be shredded. Tube tires are the worst!
    TW200 number 2. 2018 1.1 miles when I picked it up.
    Jul 2012
    Wet-ern Washington
    1,410
    Have you heard of Ride-On? https://amzn.to/2sg0shL
    Gulfrider, Ken and Elvesus like this.
    - Leisure Time Larry -
    Feb 2018
    Tulsa
    89
    Never heard of it. I had already put the thick green slime in the tire before ever getting the screw. That was a tubeless tire. I will check into it more.
    Feb 2018
    Tulsa
    89
    OK so I was using the wrong type of slime. I was using the tubeless type rather than for a tube tire. When I put in the new tubes I will use the correct type and update if I have issues.
    Dryden-Tdub likes this.
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    Haven't seen a heavy duty rear tube, someone should make one. Yep, that ride-on is what I use also. I use it in my street bike too to balance also.Wonder if we could use these like mountain bikes? Maybe 2 side by side?https://www.amazon.com/RhinoDillos-B...lat+prevention
    Ken likes this.
    2005 TW200
    2007 Sportster 1200
    May 2014
    Florida Panhandle
    587
    https://www.amazon.com/Fat-Bike-Tire...lat+prevention, this 1 for fat tire mountain bikes. Maybe work too?
    Ken likes this.
    2005 TW200
    2007 Sportster 1200
    May 2014
    Florida Panhandle
    587
    https://www.amazon.com/Fat-Bike-Tire...lat+prevention, for fat tire mountain bikes, even wider. This could prolly be used in the front as well I would imagine.
    Ken likes this.
    2005 TW200
    2007 Sportster 1200
    Hailey, ID
    3,377
    They would work for goat heads, smaller cactus spines, and the like that got between the lugs. Since the TW is MUCH heavier than a fat tire bike, nails, dry wall screws and the like would probably get through. I put my faith in Ride On. Never had a flat in 16,000 miles.
    Gulfrider and Ken like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    18,843
    I keep telling myself year after year to go ahead and pull that nail out of my Duro ATV tire and fix the Ride-On filled tube properly.
    But that darn RideOn keeps holding the air in despite an 8 penny nail piercing the carcass.
    The day I noticed the nail I went ahead and pulled the nail out as per manufacture's recommendation.
    Well, she kept on leaking and would't stop!
    Thinking that Mrs.Fred's little darling was many a mile from any form of help I went ahead and stuck that darn nail back in.
    Hissing stopped. Have not lost pressure in over two years. Nail is still there.
    So RideOn gets a good review from me.
    There are several ways to go tubeless via sealing the spokes on rear TW wheels.
    The trailer wheel conversion via either 12" or 14" rims is another good tubeless option.
    Tubesless T-Dubery is on my bucket list
    Ken and Gulfrider like this.
  1. Replies: 11
    Last Post: 10-02-2015, 06:30 AM
  2. ***FOUND***WTB left side (stator side) case for a 1996.
    By Pelon in forum TW200 Classifieds
    Last Post: 07-21-2014, 11:37 AM
  3. Torque specs for right side crank case? (shifter side)
    By BikeNerd21 in forum Technical Help
    Last Post: 05-21-2014, 08:20 PM
  4. Right Side / Brake Side Passenger Foot Peg and Bracket
    By natehunts in forum TW200 Classifieds
    Last Post: 08-31-2013, 05:07 AM
  5. GUYS WITH ATV TIRES, CHECK THIS INNER TUBE OUT.
    By slowpoke in forum General Discussion
    Last Post: 12-28-2011, 08:44 PM
