Need advice on buying one
Results 1 to 6 of 6
    Junior Member rger8's Avatar
    Dec 2012
    Calif.
    4
    New here to the forum. Looks llike a great site and I am hoping to learn from everyone. Just need some advice.
    I gonna be looking at a 2006 for $2600. I live in So.Cal. The bike has 1500 miles on it and second owner. This guy used it once and it has sat for about a year. It turns over but wont start. I can only assume the jets are clogged up. Would that be a good assumption? Is there anything else I can check to make sure thats the issue? If it's really clean, should I take a chance on it? If there is anything else to check on these when buying used please let me know. I know nothing about these bikes but they sure look fun!!! Is the price fair. They seem a bit high in this state.
    Thanks much for any info!!!
    Jun 2012
    Southern Michigan
    269
    Check compression.
    See if fuel will come out of the carb drain screw.
    See if there is spark.
    See if you can get it cheaper. That is a little high for a non-running bike in my opinion.
    May 2012
    Tucson, AZ
    976
    If the bike was running and in top condition, that would be a decent price. These bikes hold their value exceptionally well. Not running, $2600 is way too high!
    Also, I seem to recall that 2006 was a problematic year. I don't remember exactly what the issues are, but I'm sure someone else on here could tell you. There was another post earlier this week describing a non-running 2006 TW.
    If you look around at dealers in your area you might be surprised what kind of bargains you can find on a new TW too. I bought my 2011 brand new (on clearance) for about a grand more than you're thinking of paying for that non-runner.
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Frosty Hollow
    13,049
    I think the problem your talking about for an 06 was the base gasket leaking if I remember right. Replacing with a 2010 base gasket fixed I believe.
    Desert, SoCal
    7,369
    Where in SoCal is the bike?
    One of us could go look at it with you. But I agree with Bullspit. Takes a lotta nerve to list a non-runner for that kind of money. I'd pass unless he wants to take an 800 dollar hit on it. Otherwise I'd tell him to call me once he took it to the dealer and got it running..
    Dec 2012
    Calif.
    4
    Thanks to everyone for the replys. I took a look at it last night and it does run with the choke open. It is very clean and sounded tight. Price does seem a bit high. I think I'm gonna look around a bit more.
    Thanks for all your help!
  1. buying a used TW. WHAT SHOULD I BE LOOKING FOR?
    By easternfrontnh in forum Technical Help
    Last Post: 03-19-2013, 07:29 PM
  2. buying my 1st TW200
    By phatrat1 in forum General Discussion
    Last Post: 10-04-2012, 07:32 AM
  3. Buying a 89 TW200
    By shiftline in forum General Discussion
    Last Post: 04-27-2012, 04:52 PM
  4. Buying Advice Sought '88 TW
    By SlowPocono in forum General Discussion
    Last Post: 01-18-2012, 07:48 PM
  5. need advice on buying a tw200 (new or used)
    By drift in forum General Discussion
    Last Post: 12-01-2010, 12:44 AM
