Mounting TW on camper tongue experience
Results 1 to 9 of 9
Like Tree4Likes
  • 2 Post By Agfrag
  • 2 Post By Fred
Thread: Mounting TW on camper tongue experience
    Junior Member Agfrag's Avatar
    Jul 2015
    21
    I took a HF motorcycle hitch carrier apart, and used four u bolts to attach it to the tongue of my tiny pop up camper. Just put about 500 miles on this rig and no issues that I can see. The Tdub clears the camper by about an inch, and I ended up using 9 straps to make sure it was tied down firmly.
    An added benefit was that the towing experience was much more stable. This is due I believe to the added tongue weight. This particular pop up camper did not have a lot of tongue weight. I could always lift the tongue with one hand easily, even with the camper loaded. It tended to jerk the towing vehicle a little bit as it didn't really have any significant tongue weight. With the TW200 on the frame, it calmed the ride down very nicely, and almost eliminated any jerking of the hitch.
    My straight edge reveals no frame bending, which doesn't surprise me, it is a pretty robust frame, almost overkill for the size of the camper.
    Attachment 179950
    Mar 2017
    Yuba City, CA
    392
    Nice setup!
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    770
    perfect, now you can bring your favorite toy everywhere you camp! Good idea
    Frosty Hollow
    13,085
    Quote Originally Posted by Agfrag View Post
    Nice license plate too!
    Feb 2015
    Maple Ridge, BC, Canada
    1,560
    Another homemade tow hauler.
    Apr 2014
    985
    ej; I think Admiral would say you meant ToW hauler
    18,828
    Very nice solution. Those U-bolts are under a lot of tension during the load-unload process though. I would want to confirm nut tightness periodically as U-bolts may tend to bend a bit more over time and vibration.
    Jul 2015
    21
    Fred, I actually bent the U bolts and plates a wee bit upon installation, but I wanted to make sure the lock nuts I used to replace the regular nuts that came with them were well seated once I tightened them down.
    And yup in my "new contraption on the road at 70mph" frame of mind, I was checking them when I stopped for breaks/gas, etc.
    The carrier (and TDub!) did not budge for the whole trip... lol, I probably had my eye on it through the mirrors way too much, but all went well.
    Mel and ejfranz like this.
    18,828
    I could see how Agfrag had cleverly pre-bent the U-bolts in order to take out potential slop as well as to provide enough threaded shank to engage the Ny-lock nuts. Probably bomb-proof as is, yet my experience is cyclical vibration can reek havoc on seemingly properly assembled stuff. So I am a fan of checking bolts periodically even if unnecessary.
    When I think at times "Oh, it doesn't matter" I then recall how Mrs.Rhodetrip had a unknown loose top engine stay mount result in a broken frame mid-way down Death Valley's Titus Canyon. That changed a fun vacation trip into a rescue adventure.
    admiral and Agfrag like this.
  1. Pulling a trailer with your TW. Experience??
    By upnovr in forum General Discussion
    Last Post: 11-26-2017, 12:07 PM
  2. Replies: 4
    Last Post: 04-03-2016, 09:55 PM
  3. Replies: 12
    Last Post: 04-10-2015, 01:56 PM
  4. TW parts galore! Does anyone have experience with Webike Japan?
    By AkiraClownGang in forum Performance and Customization
    Last Post: 08-23-2011, 08:09 AM
  5. Tongue weight & wheel chock placement
    By Tirebiter in forum General Discussion
    Last Post: 05-08-2011, 09:37 PM
