winter boredom
Results 1 to 10 of 14
Thread: winter boredom
    Senior Member howardgene63's Avatar
    Mar 2012
    central missouri
    234
    Here is my take on the crescent hammer. The 22mm axle hammer with 12 gauge copper wire rapped handle.[img]<a%20href=[/img]">
    Sep 2012
    Northwestern Oregon
    1,092
    Very multi-purpose. How did you connect the wrench to the head?
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    excellent job on that! I'll add one to my kit.
    Mar 2012
    central missouri
    234
    OWT I cut the open end off the combination wrench with the chop saw, ground the end on the bench grinder until it fit tightly in the hammer head, then welded it top and bottom with the mig welder. Wrench handle held 5-6 feet of wire. Just noticed I mispelled wrapped.
    Jun 2012
    Southern Michigan
    269
    I like it!
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Nicely done. Would this be for your home shop or on the trail tool-kit? Gerry
    Take care my Friend.........
    Mar 2012
    central missouri
    234
    MRGIZMO this would be for my trail tool kit, wich is a little on the bulky side, but I would like to try to do all my home repairs with what I carry on the bike.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Good job on multi-tooling..........what brand of MIG do you have...if I may ask?.
    Mar 2012
    central missouri
    234
    Frog I just have a lincoln flux core welder 120 volt at home wich is fine for 95% of what I do, and would have worked fine for this project, but I welded this on a miller 200 at work (saves my wire). A couple of guys I know have the hobart 135/140 amp handler 120 volt, They seem like a great machine for the home shop for the money.
    Paradise, Calif.
    3,513
    Howardgene, having been inspired by these 'multi-tool' ideas that have been presented I got an idea for you; The ball-peen end of your hammer may not be a feature that you are likely to use on the TW. If you carefully grind it down to represent a 'stud' onto which you can slip a 3/8th's or 1/2 inch drive socket the use potential may really expand. Granted, it will not ratchet, but with quality (many facets) sockets it will still be very useful (I believe). You can then also use sockets with the appropriate allen-heads. Gerry
  1. Winter project
    By Leben in forum Performance and Customization
    Last Post: 05-23-2014, 09:32 AM
  2. Winter riding
    By stephenmarklay in forum General Discussion
    Last Post: 03-03-2013, 06:12 PM
  3. Winter fun
    By howardgene63 in forum General Discussion
    Last Post: 01-01-2013, 02:03 PM
  4. maybe we can do this to the tw for some winter fun
    By ridgeline in forum Test Forum
    Last Post: 10-15-2012, 01:09 PM
  5. winter prep
    By [email protected] in forum Trails, Off-road, and Adventure Riding
    Last Post: 09-09-2012, 09:05 AM
