Always double check the dealer!
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree63Likes
Thread: Always double check the dealer!
    Member molson42's Avatar
    Sep 2018
    Southern California
    89
    Ok, I usually do my own basic maintenance but almost always go to the dealer for the first service, trusting they'll check everything and make sure nothing is wrong.
    Well... after having to loosen my chain just a bit, because the dealer tightened the crap out of it, the "wax" pasty like lube they put on is beginning to wear off... revealing the chain is rusty. Now, the chain actually was beginning to rust when I dropped if off to the dealer and I specifically asked if they would clean and lube the chain, even though I brought it to them in poor condition. They of course said the would. Well it appears to me they only took a cloth and wiped it down and then gooped on whatever the crap it is they use for lube. I washed rooster this morning, cleaned & lubed the chain. I only wish I took a before picture.
    Has anyone else had this kind of crappy service from their selling dealer?
    Sent from my SM-N950U using Tapatalk
    jtomelliott49 likes this.
    2018 TW200
    2016 Victory Gunner
    Amsoil Dealer of Montclair, CA
    Save up to 25% with a Preferred Customer membership!
    Feb 2017
    Waretown NJ
    544
    I would have no problem calling the service manager and letting him know you dont like to complain for the sake of complaining but you also don't like to be taken for a moron. Also if he isn't made aware he may not realize for a long tine that he has is employing a crappy mechanic. You might be saving someone else problems with a bike they trust to the dealer
    87 TW
    Mar 2015
    Ynys Môn
    4,571
    The "wax pastey" stuff they put on is perfectly acceptable - "surface rust" is a fact of life, unless you regularly lube the chain. Unfortunately, the white pastey stuff doesn't immediately dissipate the rust, meaning the rust is still visible, rather than still being there and invading the links.
    Asking a dealer to "clean" the chain is quite frankly "insane" - as is the very notion itself. Your version of "clean" is never going going to match the dealers. I would recommend a "X" ring or "O" ring chain, and that you make no attempt to clean it other than to clear it of sand etc. Anything else it just going to chase the crap into the links.
    I apologise if this answer is not the one you were expecting, but sometimes, it just has to be said
    I applaud your intent, but sometimes the solution makes it worse ......
    NVcowboy, Peterb, molson42 and 8 others like this.
    - Hidden Content
    Sep 2018
    Southern California
    89
    I get what you're saying and appreciate your candor. The fact that my chain was so tight (less than 1/4" slack) and then seeing what I saw under the wax lube just made me mad.
    I guess I expected they would clean the chain as in spray it with appropriate cleaner, scrub it down with a brush, wipe it down and then lube. The truth is this is the first chain I've owned in a long time and I guess I expected too much from the dealer.
    I will call them to let them know, however, that when some asks them about cleaning the chain, they really should explain what they'll do and what they won't do. Like you said, my definition of cleaning is apparently much different than theirs.
    I would respectfully disagree, though, that asking the dealer to clean the chain and expecting them to do a thorough job (when they tell me "yes we'll clean and lube your chain) is not insane. I've been in the same business for the past 25 years and when I tell a customer I'm going to clean their generator, as a part of the maintenance they're paying me to do, I don't have my technicians just rinse it off. We do a thorough job because word of mouth is the best advertisement.
    2018 TW200
    2016 Victory Gunner
    Sep 2018
    Southern California
    89
    Quote Originally Posted by Maxpower View Post
    I will be calling them, for sure. I'd like to think that it's not a common occurrence but I'm sure it is. I do expect a lot when I'm paying a professional to do a job.
    Purple and jtomelliott49 like this.
    2018 TW200
    2016 Victory Gunner
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,718
    It has been said, if you want something done to your specs, you have to do it yourself.
    molson42, elime, 2scoops and 3 others like this.
    Sep 2018
    Southern California
    89
    Quote Originally Posted by plumbstraight View Post
    True story!
    2018 TW200
    2016 Victory Gunner
    Jun 2014
    Bel Air Maryland
    4,169
    I won’t take any of my vehicles to a dealer unless I know the mechanic. I couldn’t imagine how much I would have spent having a dealer service my TWs I’ve learned to service my TWs from all the great members on this forum and it’s done right. Replace that damn OEM chain with an X or O ring chain now and save your OEM for an emergency replacement.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,047
    I have to say you often get what you pay for with dealer services. How expensive was this service you had done at your selling dealer? Around here the dealers get between $75-$100 per hour for shop time spent on your bike. I suspect the chain service you requested and expected if done to your specific specs would have required removal of the chain and a good soaking in rust removal solvent plus a good brushing with a wire brush and then re installing it, for adjustment and lubing. Easily a good hour of shop time if done right so between $75-$100 for that part of this service alone.
    Face a couple facts here. The standard factory installed chain on a TW is just a basic inexpensive roller chain, nothing special at all and certainly not worth spending $75 on to get it cleaned and lubed. For $75 you can get a high quality X ring chain and just forget about it for a very long time.
    Shoddy workmanship from dealer service mechanics is a rather common occurrence in the MC world. More often than not the actual certified mechanics are working on real technical issues while a couple of lesser qualified Set Up guys are doing the menial work such as chain cleaning and adjusting. Call these guys, mechanics in training under some minor supervision of the real "certified mechanic". Your stock chain is subject to rust no matter how well it is maintained. It is subject to needing constant adjusting as it wears. Owning a motorcycle is a very expensive proposition if you plan to have it fully maintained by the dealer for any and all service and adjustments. DIY is the name of the game when you buy a MC and the only time it should require dealer service is when something truly does brake or go out of serious adjustment. If a little rust on any part of your new bike appears that you don't like then the guy to take care of this issue is you unless you have very deep pockets. Complaining to the dealer over such minor issues will likely not serve you well in future servicing issues as the dealer will consider you a unsatisfied complainer over minor issues. I will go out on a limb here and say that very few of the TWs owned by members here on this forum ever go to the dealer unless something serious does go wrong and then usually only if they are under the original warranty. If you don't own a wrench and know how to use it or have no mechanical understanding of MCs in general then a TW is not the bike for you. They do in fact require a pre flight check almost every time you toss a leg over the seat.
    1987 Yamaha BW350 Big Wheel
    Frosty Hollow
    13,049
    I think your chain looks great. Your standards must be extremely high and there's nothing wrong with that just different from my point of view. I think potential crappy service from a dealer is something to watch for but not over a chain...which hopefully gets well used.
  1. Double TW Iron Butt Saddlesore completed.
    By lizrdbrth in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-11-2016, 11:16 PM
  2. Replies: 4
    Last Post: 01-07-2015, 12:42 AM
  3. Replies: 34
    Last Post: 11-26-2014, 11:56 AM
  4. Double Your Pleasure, Double Your Fun
    By old white truck in forum TW200 Classifieds
    Last Post: 03-20-2014, 09:21 PM
  5. Double Take mirrors?
    By cigardog57 in forum General Discussion
    Last Post: 12-14-2010, 05:23 PM
