Street air pressures Shinko 244?
Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By TW-Brian
Thread: Street air pressures Shinko 244?
    Member BuddyMack's Avatar
    Jul 2016
    Huntsville, Alabama, USA
    68
    Who has so advice on street air pressures on the Golden Boy? What about the Stock Rear?
    Sent from my LG-TP260 using Tapatalk
    Now Hidden Content on my 2nd TW - 2002 TW200 33k miles - 130 main 34 pilot - 244 Golden Boy Front - 34 BS rear - ATV Bar - New Rally Perches, Master Cylinder, and levers. This one may take a bit to whip into shape but we'll get there!
    Pleasanton, CA
    5,719
    I'd say that Yamaha's recommended pressures are about what I would suggest for the Golden Boy and stock rear tire, somewhere between 18 and 20 psi.
    Member SwampFox's Avatar
    Dec 2014
    Summer Grove, LA USA
    76
    We run the recommended 18psi in our 4.60-18 244 Goldenboy on the front - works well enough for asphalt-to-gravel-to-asphalt roads we generally ride.
    I'm thinking we my replace the front Goldenboy with the similar IRC GP-1 at the next tire change.
    Lee
    2001 TW200
    2013 CRF250L
    1982 MB-5
    1998 R1100GS/CSM Sidecar
    2012 Zuma 50F + 2006 Burgman 650/Texas Ranger Sidecar <<Mrs. SwampFox's Scooters
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    734
    I just had a new 241 installed and I got 20psi..I think the rear I put 22...not bein a skinny guy
    2005 Tdub
    Senior Member UncleRandy's Avatar
    Feb 2015
    Alaska
    165
    The Golden Boy is so stiff that little deviations in air pressure are unnoticeable to me. 18 seems good, but your weight, gear and temperature may require adjustments.
    6,975
    I have a Heidenau K60 on the front of my TW. I tried 18 psi and the knobs were wearing down at an angle. I up it to 30 psi and try to use the back brake a little more and the knobs are now wearing down flat, or close to it. 98% of my riding is asphalt.
  1. SHINKO SR241 Tire Pressures
    By maddawgj in forum General Discussion
    Last Post: 12-18-2017, 03:52 PM
  2. Shinko 244 Front Tire
    By Phantom99 in forum Performance and Customization
    Last Post: 07-31-2017, 12:30 PM
  3. Shinko 244 vs Kenda k270 vs IRC GP1 whos the winner?
    By weeman in forum Performance and Customization
    Last Post: 05-17-2015, 01:49 PM
  4. FS: Shinko 244 "Golden Boy" front tire (NY)
    By 98940 in forum TW200 Classifieds
    Last Post: 05-18-2012, 03:34 PM
  5. Kenda K270 / Shinko 244 Rear Tire - Requests
    By praeses in forum Performance and Customization
    Last Post: 11-19-2011, 08:50 PM
